Loose the reflectors asap.
At least have the decency to put some baggies over the top. This ain't the TdF where every second counts.
Bought a decent Lava lamp
[/QUOTE]
The original and best one! :cool:
The original and best one!![]()
are lava lamps a huge fire hazard?
usually left on for long periods, gets very hot to the touch, made of glass, hot stuff inside = fire
A 10mm OD, 8mm ID steel tube and a 40 tooth, 48DP gear..
..these will eventually go into this thing once a few other parts (gears and bearings) arrive.
Still very much a work in progress. It's basically a game controller using an Arduino Leonardo, some wood, some potentiometers, gears, wiring and switches to replicate an old arcade controller.
I've salvaged old lego sets, hard drive caddies, stripped electronics from consumer goods and used an old curtain pole hanger to get thus far. It works ok but I think it needs better bearings and gears.
Is it like the old Star Wars arcade controller?
That's not one I've come across before! Looks pretty decent, what gear will you be hooking it up to?
