Don
Aye, replace it with a MPS Flow 400! It's dp based (no moving parts) rather than a turbine meter (moving parts).
id agree with going the aqua computer aquaero, then just add what you need as and when
i love it, its costly to get started tho
i have my temp sensor being picked up from its high flow meter, which i have after my gpus and before my cpu block
i have 2 other temp sensors, 1 out of my last rad and one going into my first rad
two of those sensors are connected to the aquaero and used for automatic fan curves, the last i use for a front of case temp for me to see
its all silent and automatically controlled with no software needed to be run, just fire it up to make changes when you like
OCTO is a very powerful alternative at half the price, you can pick one up, some temp sensors and flow sensor for the same price as an Aquero
I bought one of these, really happy with it.
What sort of flow rate should I be looking for?
With my current pump profile i'm getting around 1.5 l/min
i use aquero LT so without the display they are the same price, the 5LT at £49.99 or the 6 is more at £90, but they allow chaining and adding more devices by the looks of it
iv not seen the OCTO before though, ill checkout some reviews when i get a chance
i try and aim for 1 gpm at my normal use, then ofc it increases as the temp rises by its self
i have an alarm setup for 0.8gpm so it if drops below then its clean out time
ill checkout a review, there must be a good reason for them to have bought out a second range, unless they plan to drop the LT in favour of the octo
the LT is tiny and does not need a bay, granted not nice looking and a pain to mount, the octo looks far easier
good to hear it uses the same software, not having to run the software was one of the major plus for AC
its nice it can be chained from the aquero so its not a wasted device should you want more from a controller, i have a few i dont use anymore as i slowly outgrew them
i use 4 channels on my aquero to run 18 fans lol
i went for it originally as i was running high wattage fans and could not find another that could support them, now mine are all weak i can run loads off each channel, i just have them on 4 to cover areas of the case
the octo is the pwm fan extension for the aquero that is also a standalone, very cool
for that price it might be a nice add on to let me swap out some fans
just at the time one of my fans is failing, good time to find this out
thanks
damm thats quite the setup
2 fans for chipset and storage? think im going to have to see some pics to follow that please
im running 3x360 rads, 1x240 thick rad, 2 gpu blocks, cpu monoblock on 1 loop, really happy with it, apart from trying to fill and empty it
but my pride and joy is the case, iv spent more on the cooling on this build than the rest of my setup combined lol
https://www.overclockers.co.uk/lian-li-pc-d888wx-8pack-edition-atx-cube-case-black-ca-739-ll.html
i love cube cases, and this one letting me keep my bays while having a front rad is perfect, tho it could do with being slightly wider on the mobo side as my gpu block is touching the window, i got lucky on that, it never crossed my mind that it might not fit lol
yep they are 16/10 rotary where able to
i have about 1 bay free down the bottom
the top two have tubing and cables so they cant be used
the bottom still has a hdd hotswap bay with 3 drives, they are just not plugged in anymore, i dont need them tbh, but i struggle to throw things away, and they are all atleast 3tb all full of crap lol
same with the dvd drive, not plugged in, but on occation iv been asked to move stuff to a usb drive for people so its handy to have kicking around
good luck with your filters, i got rid of all my magnetic ones sine they wont stick to this case lol
iv bought a dyson with the little brush attachment cleans them all really well for regular use, i still use the paintbrush for better cleans, also picked up the xpower blower https://www.overclockers.co.uk/it-d...uster-and-vacuum-suck-and-blow-kb-004-id.html
i only use it as a blower, i highly recommend it
those two just let me give it a 2 minute clean when im in the mood lol
