Apple are affected also : https://support.apple.com/en-us/HT208394
Yes, I saw someone post a screenshot on reddit of that power shell scrip that verifies whether the fixes are applied and kernel VA shadowing was disabled on Ryzen and marked as not necessary.Are we sure that on Windows, the fix that slows things down is disabled for Ryzen?
Everything. Once in it's full control, do what you like.
I guess this more lethal to the average home user than i first thought.There's already an example application that can grab anything you type in, kinda like a keylogger but easier to employ. Mozilla I think also has a Javascript-based exploit example.
Not entirely true. The minimums of one user has tanked
Indeed.
I just finished running Rise of the Tomb Raider benchmarks, 1080p, very high preset, FXAA.
Unpatched:
Windows patch only:
- Mountain Peak: 131.48 FPS (min: 81.19 max: 197.02)
- Syria: 101.99 FPS (min: 62.73, max: 122.24)
- Geothermal Valley: 98.93 FPS (min:76.48, max: 117.00)
- Overall score: 111.31 FPS
Windows patch and BIOS update:
- Mountain Peak: 135.34 FPS (min: 38.21 max: 212.84)
- Syria: 102.54 FPS (min: 44.22, max: 144.03)
- Geothermal Valley: 96.36 FPS (min:41.35, max: 148.46)
- Overall score: 111.93 FPS
Average framerates don't seem affected.
- Mountain Peak: 134.01 FPS (min: 59.91 max: 216.16)
- Syria: 101.68 FPS (min: 38.95, max: 143.44)
- Geothermal Valley: 97.55 FPS (min:46.18, max: 143.97)
- Overall score: 111.62 FPS
https://np.reddit.com/r/pcmasterrac...nce_impact_of_windows_patch_and_bios/ds88idv/
Edit: I'll leave this here but just realised that with out a graph or the removal of outliers my statement is not entirely accurate.
Do not do this, if it's a Windows Server OS then the patch will apply BUT it will not be enabled. Please read the MS articles.
You have to manually enable the patch (you have to add 2 reg-keys), which will then potentially cause/give a performance impact.
EDIT: I would seriously recommend you also read this article - https://support.microsoft.com/en-us/help/4073225/guidance-for-sql-server
Unless the testing is purely functional, it should really be run in an environment that's representative of production - i.e. with the patch enabled. It'll be no good proving performance in test only for it to be slower when released to live.
I realise I've made a lot of assumptions above![]()
Plus if you use production data in the test environment then security is just as important as in production. I imagine in testing you'd want to try and emulate production as closely as possible to minimise any surprises that might happen when moving from testing to production.
No point running tests on a test database with 100MB of data if your production database is several GBs.
I think it is going to take intel some time to get the confidence back from a lot of people and businesses
For the life of me I do not understand these people who are saying "No real drop in FPS doesent affect me" and are even saying they wont install patch because it will hinder performance. Are you people nuts? Are you ever going to go banks site with your computer? Ever going to be putting Credit card info on anywhere? Ever logging in on any site? Ever logging to program on your computer? If you are and dont have every last patch and firmware u are absolutely ******.
certain sense of safety in numbers
Damn, thats a hell of a lot more than 30%
AMD has it's own protection built in to its cpu, and so only if you can actualy get access of the computer can you use the exploit. So AMD are almost bomb proof, so why the need for a patch.
Intel on the other hand, well you should have used 2 glued togeather deasktop cpu's to save all bother. LOL!!!
gives a certain sense of safety in numbers.
If you're a victim alongside many others, you're still a victim
