For meltdown yes. However, from what i have read Spectre affects AMD stuff as well.
Also from what i have read meltdown is fixed with the OS update but it is Spectre that needs the microcode update.
The problem isn't trust, it's need. If your company requires 500 more computers, or if a server farm needs upgrading you can't simply not buy and if AMD computers aren't available you only have one other choice. That is the big issue, computers run the world, the choice to not buy doesn't exist for business. If Amazon require expanding their cloud capacity they can't just wait, they lose business doing that to someone else who would buy computers to expand their capacity instead. So Amazon have to buy and again they can only buy what is available. I fully expect companies to think heavily about buying AMD and many will, but AMD will run out of chips and given no other option trust or no trust, they'll buy Intel.
Now if GloFo had the same manufacturing capacity as AMD and it wasn't already assigned (which itself is a situation that wouldn't happen, you don't keep 20billion+ worth of fabs sitting there idle waiting for this kind of situation) then I think trust could massively massively hurt Intel, but in the current situation it will likely make much less difference than it should.
Damn, thats a hell of a lot more than 30%
Sorry to burst your bubble, but that's not what safety in numbers means though - it means that most get away unscathed as a minority pay the price.
Abundant technology exists to enable scale and automation - it's very little cost to attack millions vs attacking a few. If you're a victim alongside many others, you're still a victim
Of course you have your own pain thresholds and unique circumstances, but don't let scary headlines put you off patching.
Good hygiene should avoid him downlaoding any compromised/injected code though, plus two factor authorisation on the critical applications means passwords are of limted use (unless the attacker is waiting ready to control your system immediately you provide the second password) ?
Most get away is exactly what I mean by safety in numbers
once I've seen how much these are exploited. If my Steam password gets hacked in the meantime, I won't lose much sleep.
Can I detect if someone has exploited Meltdown or Spectre against me?
Probably not. The exploitation does not leave any traces in traditional log files.
Can my antivirus detect or block this attack?
While possible in theory, this is unlikely in practice. Unlike usual malware, Meltdown and Spectre are hard to distinguish from regular benign applications. However, your antivirus may detect malware which uses the attacks by comparing binaries after they become known.
How skilled a hacker is needed to crack these weak points anyway?
I was wondering the same thing. Hopefully not.Doesn't this require a new design paradigm in cpu design
They have all had at least six months to think about it but yes, it will probably involve a lot more work....
It's going to take a while for Intel (and all CPU manufacturers) to fix this at the hardware level
