Caporegime
- 8 Jul 2003
- In a house
Yet they tell us Windows 10 auto updates is good for us.
Those updates you can't stop from installing that hose yer rig all the time must be a nightmare
Nvidias GPUs ?
https://nvidia.custhelp.com/app/answers/detail/a_id/4611
EDIT:
The drivers are out now.
Just disable the windows update service, then again that mean sod all updates.
I thought it was Spectre that requires a BIOS update with microcode plus various software patches and that Meltdown was purely an O/S patch?No, they are not telling you everything, that is for Spectre 1, ask them about Spectre 2 and particularity the Meltdown part of the exploit, Meltdown should require a BIOS patch.
What is all this nonsense? Windows 10 updates for me are permanently off forever and nothing will change that. I'll let you know if something bad ever happens. What do you guys keep in your PCs I wonder? Everything is on the cloud and needs two-factor auth these days.
haXXors were an early noughties meme so Relax...
They don't. Nvidia is being responsible and mitigating against these vulnerabilities in the CPU hardware by changing how things are done in their driver.I didn't even know GPU's had anything to do with this I thought its was just a CPU thing, just checked the experience and it is downloading the update 390.65
"The cloud" is a vague term. My server in my home acts as my "cloud" storage and I access those files all the time from my desktop, laptop, and phone.What is all this nonsense? Windows 10 updates for me are permanently off forever and nothing will change that. I'll let you know if something bad ever happens. What do you guys keep in your PCs I wonder? Everything is on the cloud and needs two-factor auth these days.
AMD's impact table states that no microcode updates are required for AMD CPUs and that OS and software updates are sufficient to fix Spectre (Variant 1), and that this will bring a negligible performance impact. If you look at recent benchmarks, it's the microcode updates to fix Spectre (Variant 2) on Intel CPUs that are causing most of the performance issues, not the OS updates. So far AMD's analysis seems correct.That's correct. On Windows, the microcode updates being rolled out are to facilitate the OS patch for CVE-2017-5715 (branch target injection). The mitigation for Meltdown is a software workaround in the OS; it's possible there could be a microcode update but that would probably only be if there a way discovered to alleviate the performance hit of the OS workaround.
Of course.well honestly amd will do it to intel just as intel will to them.already seen it in media.it is a selling point if you can prove your product isnt effected by a issue or less so than your rival.
amd old athlons getting screwed on win 10 with updates
https://answers.microsoft.com/en-us...r/6c015632-2a45-4725-a882-f231f8c88f36?auth=1
According to Microsoft, some AMD PCs are in an unbootable state after installing the recent patches because their chipsets "do not conform" to the documentation that was provided to Microsoft when it was developing mitigation techniques against Meltdown and Spectre. In simpler terms, AMD's provision of incorrect and/or incomplete information regarding the CPU has resulted in potentially thousands of machines being rendered unusable.
