She really does sound like wife material lolThe wife is currently using it to play erdtree dlc. She has platinumed all the souls series for me.![]()
Wildly off topic sorry. But does anyone know how to connect a Philips hue bulb to the TV? I have an ambilight TV but it just won't see the bulb (trying with Bluetooth) Sorry for off topic,but it saves opening another thread.I still pick the ps above all of the above. Really love the eco system, ease of use, trophies, everything. Still have a steam deck and great pc but the ps is what's plugged into my expensive TV and amp. Will be buying the pro and the inevitable ps6.
Honestly don't think its this, we would have seen precedent for it before on other cpus, have we?![]()
Most of the complaints are from running Cinebench or Unreal 5 games. If you have an early manufactured CPU, there's a suspicion they're not affected, but nothing is confirmed.I've not had any issues at all with my 13900k, any idea what exactly you can do to test if its on its way to becoming a dud?
I bought on release, they are affected, degraded my second cpu on cinebench, sure of it now I've been reading all this stuff.Most of the complaints are from running Cinebench or Unreal 5 games. If you have an early manufactured CPU, there's a suspicion they're not affected, but nothing is confirmed.
Do you mean the KS in your sig? A KS might not count as being early manufacture, because they're released after the other K CPUs? I don't know what dates we're supposed to be looking for specifically though.I bought on release, they are affected, degraded my second cpu on cinebench, sure of it now I've been reading all this stuff.
Using a contact frame?I bought on release, they are affected, degraded my second cpu on cinebench, sure of it now I've been reading all this stuff.
Afaik what I read was (early manufacture) 2022 or early 2023, but I can't find the thread now. The year is the first number, so X214 would be 2022 and the second two are the week, which would be April.Ah okay, yeah I'm on my third KS. SP of the other two were lower than my current one.
My current one is X249L595PAfaik what I read was (early manufacture) 2022 or early 2023, but I can't find the thread now. The year is the first number, so X214 would be 2022 and the second two are the week, which would be April.
It did seem to be (from the way he talked) that he was just assuming that W680 was ran 100% at stock and there were incorrect assumptions made by other news outlets too about what W680 can actually do. It is true that Supermicro usually use the Intel defaults, but W680 as a chipset does not have any restrictions and as you have noted, can overclock both the CPU and the memory.Furthermore, looking in the BIOS manual for that motherboard (W680) there are the same overclocking and AI tweaker settings so they can't be wildy different from consumer boards.
We're not 100% sure of anything, both voltage and power draw being the cause are just speculation.Are we 100% sure this isn't the unlimited power draw that is causing this?
Yeah, it does seem to be a lot more common with modern CPUs, it was like 0.001% would die in-situ before 11th gen / Ryzen. I definitely would think twice before buying a tray/1 year warranty CPU instead of a boxed one, whereas I'd have no concern about that before.It's a weird thought that a processor can die.
