OK I am upgrading from an i7 4770K
I like the Ryzen 5950, but would I be better sticking to intel and what is the equivalent?
Around £500 budget
Unless manually changing settings Ryzens max at 140W of heat.If you are thinking of going with Ryzen after using an intel system just make sure you do some research on appropriate cooling because the Ryzen 5000 series can run very warm
Around £500 budget
If you are thinking of going with Ryzen after using an intel system just make sure you do some research on appropriate cooling because the Ryzen 5000 series can run very warm, also the 5950X is around £750 so it is out of your budget but the Intel i9 10900K / i9 10900X are in your ball park.
Im not sure a 5600X is worth it even with the price being slightly reduced recently, sure you can upgrade it to a 5900X in a few years time but you'll still likely end up spending as much had you just gone with a 5900X in the first place.5600x, mid range, clear upgrade path in future with 5900 or 5950.
Or wait to see if am4 is about to be dropped then jump on first am5 cpu
Whats your idle temps? I upgraded from an I7 950 to a I7 9700K a year and a half ago.I went for intel for my recent build, 9700k and I wish I went with Ryzen. This CPU is so hot and has no overclocking headroom. No upgrade path either
CPU idles at 35C at the moment with a room temp of 26C.
Runs as long as 30C and cooled by an 240m AIO with 2 x redox fans, I have not tried any overclocking as its not been needed.
Agree on the limited cpu upgrade path, my other PC has a 3600 at stock
