- 5 Nov 2014
Interested in this thread as im in the same position. Joxeons comments about upgrade path made me think, potentially worth finding the extra cash now and get the 5800 over the 5600
Unless you're playing at 4K i think it would.
The 11400K is a great CPU for its price, it is cheap, but its cheap for a reason, i'm not knocking it, it has its place but when we are talking about RTX 3070 and up territory that CPU is a false economy.
It will be fine. You might get a few frames more with a 5600x but for the cost it's not worth it.
That 11400k looks very appealing. I went from 4600k to the Ryzen 5 3600. Really don't have a preference in brand just best bang for the buck as they say.
It is a good CPU, i like it, its capable and its cheap, @Joxeon is right, quite often its just as capable as the 5600X, which is a much more expensive CPU.
However, what you're seeing there is a limitation of the GPU, not the CPU, i guess the simplest way to describe it is the 11400F is just as capable, in a lot of cases driving a high end GPU as the 5600X, but that is not the same as saying the 11400F is just as fast, it isn't, that would be a bit like saying a Ford Focus is just as fast as a Porsche, it is at 70 MPH, now put them both on the Autobahn.
People sometimes make the mistake of looking at these bar charts and thinking this CPU costs £150 and this one costs £300 yet they both have the same sort of bar length, i'll get the cheaper one, of course, then a new round of GPU's comes along, they upgrade and are stunned to find their performance has not changed as much as they expected.
Take the Ryzen 3600 as an example, a lot of reviewers said things like, and i'm using an actual example here "the 9900K is only 6% faster than the Ryzen 3600" yea, with a 2080TI, now we have an RTX 3080 and the 9900K is 20% or more faster, because a Ryzen 3600 was just about as capable driving a 2080TI as a 9900K is not the same as "just as fast" and if you bought one last year, nice and cheap and now you're looking at a 3080 or even a 3070 frankly with the latest games you have to upgrade the CPU again and you're spending £300 anyway.
Its almost as if these reviewers are deliberately peddling products with built in obsolescence, they are not, they are just a bit stupid and think they are saving you money and driving down prices, AMD and Intel don't think so, they are looking at this thinking "you carry on my friend"
That's why i say its a false economy, unless you plan on keeping the GPU and CPU combo for a few years.
I'm beginning to think the midrange, and upgrade more often, is where the value is. Selling sooner also returns more for your old gear.
Yeah I am starting to see that too. I might just wait till AM5 but then go for more semi-regular upgrades rather than waiting a long time between upgrades!
Been saying this since AM4 was launched.![]()
I'll weigh it up at second gen DDR5 and see how it stacks up.
If you take your time, use proper fittings and double check everything you should be fine. It does need a lot more maintenance though and can be very expensive to get in to.
Expensive is an understatement, you can quickly rack up the price of a rtx3090 just on your cooling
Been there and done it with water (CPU) and phase (CPU) also destroyed a GPU trying to watercool it and gave up on that.Expensive is an understatement, you can quickly rack up the price of a rtx3090 just on your cooling
Very costly for little gain these days, GPUs are about the only thing that benefits and it's too fiddly to begin with.
The ryzen will age better but not much better and buying a 11400F and just upgrading to whatever budget platform is flavour of the month in 3 years time will certainly beat buying a 5600X and then upgrading to a 5900X in 3 years and will probably have a similar net spend.It is a good CPU, i like it, its capable and its cheap, @Joxeon is right, quite often its just as capable as the 5600X, which is a much more expensive CPU.
