She could compete if she took testosterone blocking medication and her times fell and she fell into obscurity for the most part.
You can compete if you take drugs to curb your natural state and make you not as good as you naturally are... Yeah, that makes sense!!
Suddenly Semenya is back to her best miraculously and destroying the field again. How is that not proof that testosterone affects performance massively.
Some other articles argued that if testosterone was THAT much of a factor, then all the other athletes found to be taking it to boost their performance would be far better than they actually are.
Over a very long period (as in years), it will make a difference, but the arguments suggest that most of what athletes dose on has very minimal results.
I'd say that this just proves whatever she took to reduce her testosterone levels is effective at curbing performance.
Well, that and the well known and proven fact that testosterone affects performance in both men and women.
In the same way that taking a single drag from a cigarette affects your lifespan, perhaps... Plus, taking steroids inhibits natural testosterone - So if testosterone is the thing you want, why do athletes take steroids and enjoy enhanced performance from them?
She has the testes, they are just inside not outside.
You have a picture of this?
An official report on her tests?
Or is she as much of a man as Lady Gaga, again?
She has no womb, ovaries etc the primary female reproductive organs.
Proof?
so the implication here is she has levels at the high end of male test levels
So she must be achieving run times at the upper end of the male categories and beating most of the men too, no?
So no, her test levels say they are miles out of female range and very much male only test levels.
Have her results been officialy published, then?
'She' also has male sex organs, she has internal testicles and no ovaries or uterus and male level sex hormones.
Official proof?
I think you're also the first person in the thread to say 'she' like that, suggesting that most people still see her as female.
This is from the link posted on the last page.
Which states nothing in regard to her womb, ovaries or testes...
It also says nothing of what nmol/L her test results showed... just states values and limits.
They removed this rule, her test went back to normal off the drugs and her performance increased, absolute proof testosterone increases performance in women despite them reversing the limit because "there wasn't enough proof testosterone improved performance in women".
OK, so I'll put a test out for you - You go drink some water and run a mile, tell me what your time is. Then go take some Rohypnol to reduce your performance and repeat the run... then stop taking Rohypnol and see what your third run comes in at.
Definitive proof that drinking water enhances performance? Or just proof that inhibitor drugs inhibit?
Normal test levels are 0.52-2.4nmol/L for women, 9-38 for men.
And what were her test results?
Has anyone actually got the figures for this?
her performance tanked which indicates a massive drop in testosterone, not just from 11 to 10 but more likely from 30+ to <10.
You can tell an athlete's actual testosterone value just from their run times?
You can map out, say, 12.5nmol/L = 100m in 12 seconds.... or 0.5nmol = -5 seconds per 50m run?
You don't need to stick them with a needle and do anything scientific?
Wow, you're good...
Only 16 female athletes would have been unable to compete with a limit of 7.5
Wasn't that 16 in every 1000, rather than 16 specifically known individuals?
