iphone down to £169
So let me get this straight
£170 pay up front in CPW/O2 and then hack when you bring it home?
Is that it? Seems like a bargain if you dont need the extra features.
Can anyone tell me how to disable the GPRS/EDGE so it doesnt access those facilities automatically? Or at least a prompt of some kind?
I wouldn't mind knowing this too, until I get my O2 simplicity SIM, my Vodafone data charges are quite painful.
Hoping that it won't be able to access any data, since I haven't put in any vodafone-specific settings, but wouldn't hurt to make sure before it goes out of my wi-fi range!
Troothalicious.
I installed this program called... "Services" through the Installer button (is that installer button something created by the dude who made ziphone?)
The services button gives you the ability to disable Edge/Wifi and SSH whatever that is. But once you disable them, the phone turns off completely.
And when I want to use the phone the services are re-enabled again :|
Maybe yours has a problem (or your ears do ;) ), mine is really loud on full volume. Have you got a friend with an iPhone you can compare with?
not my ears, i just tried turning the volume up and down and there is no difference to the level of volume......................
What is that button above the volume button do? and is there some in phone setting that i am missing? may be i am stuck in some silent profile or something ?
Any one heard anything from O2 about refund yet?
Thats right.
Walk in, walk out, unlock. Up yours O2. :D
just tried calling myself from the landline, it just vibrates and doesn't ring.....
Above volume control.
When you can see the orange dot its set to vibrate. Just move to the right and its set to ring.
Got to settings ------> sounds to check that ring volume it on etc etc
under sound i have it to max
the orange dot above the volume is NOT showing
Turned off vibrate in the settings
Called from landline
the incoming call screen comes on, not a beep, no vibrate.
Do you get any sound out of it whatsoever? Lock sounds? Speaker phone?
When you switch it when you look at the screen does a bell appear on the screen?
Any sound at all? Keys, lock sounds etc?
Troothalicious.
So anyone figuered this out?
something REALLY strange is going on
none of my music would play, i mean it doesn't even play. the timeline bar doesn't move....
and no, not heard a beep out of it, not anthing, not keypress, nothing.
i got it unlocked fine ! the phone works, just no sound........
