*sighYep and also something done retroactively, like stickers on certain parts of the lens to reduce it (similar to when driving abroad). Then added to MOT checks.
You know beam pattern is already checked right?Yep and also something done retroactively, like stickers on certain parts of the lens to reduce it (similar to when driving abroad). Then added to MOT checks.
What sort of extra checks do you think the DVSA should add?Then added to MOT checks.
I would put some of this down to lazy PDI checks not even looking at headlight aim. My cars headlights were dangerously low when I picked it up. How many are out there for the first three years with headlights dazzling people constantly.Yet loads of cars with LED headlights are still dazzling everyone and making night driving more dangerous. To a point where the government is having to investigate...
Absolutely this. Similar story with my Hyundai Kona - blinding out of the factory. Took it back to the dealer, all fixed in about 10 minutes; 10 minutes that probably should have been part of a PDI.I would put some of this down to lazy PDI checks not even looking at headlight aim. My cars headlights were dangerously low when I picked it up. How many are out there for the first three years with headlights dazzling people constantly.
I’d be in favour of a lumen limit, even well adjusted cars are blinding at junctions with inclines
Usually a load/compression sensor on the rear suspension, which then lowers the headlight tilt to compensate for load causing "nose up". If the original set point is wrong then yes, the lowering will also be wrong.How does the height setting work for LEDs/xenons as they auto adjust. Is it the 'default' height that if set wrong means they can never adjust low enough?
You can still manually adjust the beam height, I do plenty to get them through an MOT.Is it the 'default' height that if set wrong means they can never adjust low enough?
Lumen and kelvin. 6000k+ is not good. Bad for night sight and it reflects brightly off everything. Especially through fog and rain, even dipped beam can dazzle people.
I think these are simply a "perceived/feelings" difference rather than a logical one, and god help anyone trying to change a feelings-based decision in the general public.
I just don't get it. My wife always complains about bright lights but it never bothers me. I do wonder whether they are looking directly at them or something.
The only time I get annoyed is when I'm in the S2000 and something like a Range Rover is 30cm off my rear. I'm so low that the light just beams straight at me. A quick flick of the rear view mirror sorts it though.
