Well that’s my line of argumentation thoroughly debunked. I suspect if you actually do a bit of research into how these screens work and how your body works you’ll discover I’m not entirely incorrect.
Why is it some people claim to be able to see a difference at 240Hz whereas others can only see it at 100Hz? Surely if this was a thing it would just keep getting smoother and smoother? And everyone would keep seeing it getting smoother and smoother?
Bottom line is that 24fps and 59.9Hz is smooth. Above that you’re looking at the same image multiple times, and you can’t differentiate those refreshes.
Dude, no offence but that is an
insane opinion, so it's difficult to take you seriously.
Playing forza horizon 5, the visuals are lovely and smooth @1440p 144hz or 165hz on my monitor. (Dell S2721DGF for info)
It's even fine at 120hz, I've tested it several times...presumably as I average about 100-120fps with in game graphics set to very high or above.
Same when playing on My LG TV, but that can
only do 120hz max.
If I force it down to 60hz, it's, well, not good.. fast moving images look juddery like it's dropping frames or something, it's especially obvious in a racing game at high speed.
Don't get me wrong, like others have said, going from 144hz to 165hz for example, I think I can't really see any difference
But the difference between 60hz and 144, is very very obvious, assuming you can run your chosen game at say an average 100+ fps.
If your PC is only powerfull enough to run at sub 80fps averages, then I can understand why you would think it makes no difference, but that's because your PC and/or monitor is a potato. I'm sorry but there's no other polite way to say it.
