Dude, no offence but that is an insane opinion, so it's difficult to take you seriously.
Playing forza horizon 5, the visuals are lovely and smooth @1440p 144hz or 165hz on my monitor. (Dell S2721DGF for info).
It's even fine at 120hz, I've tested it several times...presumably as I average about 100-120fps with in game graphics set to very high or above.
Same when playing on My LG TV, but that can only do 120hz max.
If I force it down to 60hz, it's, well, not good.. fast moving images look juddery like it's dropping frames or something, it's especially obvious in a racing game at high speed.
Don't get me wrong, like others have said, going from 144hz to 165hz for example, I think I can't really see any difference.
But the difference between 60hz and 144, is very very obvious, assuming you can run your chosen game at say an average 100+ fps.
If your PC is only powerfull enough to run at sub 80fps averages, then I can see why you would think it makes no difference, but that's because your PC is a potatoe.
It’s difficult to take advice from someone who can’t spell potato but moving on, I’m not saying you don’t believe it. People believe all sorts of things. But they’re not backed up by science. Why can you not see any benefit between 144Hz and 165Hz? Because maybe your reality filter is finally working properly and the placebo effect has worn off?
Like I said, once you have a graphics card with a frame rate faster than your refresh rate it’s pointless paying more for the graphics card because even people who can’t spell potato know the refresh rate has to be as high as the frame rate. So they had to sell these high refresh rate monitors or people wouldn’t continue to buy stupidly expensive graphics cards. QED.
