Man of Honour
- 23 Mar 2011
- West Side
No the gpureturn the psu?
ok. thank you for your help also and every one else. sad to have to return it. you guys think a straight replacement would be ok or would it be worth getting another brand?No the gpu
does the fact it says engineering sample not odd also in the benchmark performance tab? been looking around for anyone with a similar reading but havent found anything yet.
Its up to you, i personally love zotac gpu there 5 year warranty is a big plus but i guess you wasnt expecting to be using it this early.ok. thank you for your help also and every one else. sad to have to return it. you guys think a straight replacement would be ok or would it be worth getting another brand?
Its a shame you can't test it in a friends pc.
Lets us know hiw you get on.
First 12 months warranty is retailer so it will be Overclockers.ive not registered it yet haha ive not had it long enough to register it before it started playing up:S and hoping i can just deal with overclockers direct. i shall give them a call in the morning. i filled out a online return form but waiting on a RMA number i think it was called.
@Brian Lovegrove
Have you made sure you are on the latest motherboard BIOS , same with the gpu latest V-BIOS and monitors on latest firmware ? Also cables used are fine and in spec ? Always use cables that came with the monitor to rule out out of spec cables. Also latest Nvidia drivers are known to have some issues too have you tried one driver back as a test or are you on old drivers and may need to update them ?
Can you take a screen shot of GPU-Z or show what bios version the card is running ?
GPU-Z can be downloaded from here
https://www.techpowerup.com/download/techpowerup-gpu-z/
Isnt the bios update for the zotac 3080 just for resizable bar feature.Can you take a screen shot of GPU-Z or show what bios version the card is running ?
If you've only just received the card then send it back to the retailer and ask for a straight swap as going with an RMA may take a while.
https://ibb.co/tMJ3dmy
my current bios etc
just to confirm mine is the Zotac GeForce RTX 3080 AMP HOLO LHR 10GB GDDR6X PCI-Express Graphics Card
https://www.zotac.com/us/files/download/by_product?p_nid=961162&driver_type=238&os=All
What makes you think it's not then GPU when he's installed his 2070 back in the system and its working fine?If he bought from OCUK or other known place then it can take less than 2 weeks, Anyway the card will goes back to him, because it seems like this is an issue with a Motherboard/Cable/Monitor rather than a GPU...
i cant im afraid i only have this system. i can say tho ive stressed tested the PSU with the 2070 im using and have had no issues at all since installing that back into the system.
You maybe able to swap it for a different model that's in stock if you don't want to wait on the RMA but yeah give them a call and I'm sure they will go through the options for you.ning. had it installed within a few hours and running less then a day before faulting. I shall call overclockers in the morning and arrange sending it back. Item looks out of stock on the website now tho so doubt ill get a replacement any time soon![]()
