That would be begging people to pirate the games?How fast is USB2? Games could start being put on USB keys, that's gotta be faster than reading a CD?
lol, i used quick reply and couldnt find them.
Of course it would, a standard 360 will not play copied games, yet with a memory stick you wouldn't have to hack the dvd drive would you?
If anything it might make piracy harder. I think your assuming they would place the files with no drm on a pc compatible file system ? There would be in effect no dvd drive to flash. The cart would interface directly with the motherboard. So you see it would then need either some kind of trick cart (a la DS) or the entire console to be hacked so it could play games with no checks eg the original xbox.
Indeed, both the PSP and DS are VERY easy to pirate because of the ability to play games from flash memory, doing the same for 360 would have the same result, IMO.A DS style piracy system is easier to do and more encouraging for pirates as you can store many games on 1 memory card compared to optical media and firmware piracy. It's undetectable too and doesn't void your warranty.
For the next gen, I'd say its too early to have completely downloadable games as few countries have the infrastructure and bandwidth to allow multi-gigabyte downloads. What will they go for instead? We'll just have to look out for what experiments the major console players try out to guage what they are thinking of.
Just because you can use one rewritable card to store games doesnt make it any easier to break the encryption etc. It just means pirates only have to buy one 'disc' instead a few boxes of discs.
