- 14 Dec 2013
My god that looks lovely!
The peel was quite bad under his lights on the rear quarters and above windows. He has got rid of 80% of it and I’d say it’s no worse than a new BMW for peel maybe slightly better.
He said he would be happy with it and he spent about 16 hours polishing using various compounds and pads to remove the peel and swirls.
Th biggest issue was swirls and holograms from the body shop using a rotary to quickly for go over it, he says he sees it all time on fresh respray cars as body shops will do a great paint job but then fly over it too quick with a rotary causing more damage which was reason for lack of gloss.
He said to completely remove peel and he said all cars have it to an extent and mine is now at good level and not to worry but a wet sanding and about 3-4 days work can remove peel 100% and give you perfect glass look but we both agreed it’s not needed as you can see from the bonnet reflection it is now very clear and mirror like.
Scared to drive it now.![]()
Sensible, get the running gear ready for this seasons track days!
R8 goes in next week for a service and brake fluid and some other checks. It needs neither service or brake fluid, but after 3 hard track days and high speed events it makes sense to get it done (less than 500 quid which I though reasonable for a V10). Also need some MORE noises checking into and considering some a geo at Centre Gravity and then some rectification of the stone chips and a detail![]()
Pole Positions seats are fantastic.
That setup is awesome for the alignment. As for someone who has done a driveway alignment with string and jack's I cannot imagine how much quicker that must have been for him to align!
Are those corner mass settings without a driver?
I'm just thinking that it would be better to have the car set up to be slightly heavier on the nearside rather than the offside so it evens out more when you are sat in the drivers seat.
Either way bet you can't wait to get it on track, such a good feeling when everything is all adjusted and set up.
Without could have done it with for perfection but my weight changes, the amount of fuel in the tank changes and the passenger can change a lot, I am not competing so happy with way its been done and it drives lovely on the road, looking really forward to Donnington, praying forecast is correct though I won't book it until night before just in case rain comes.![]()
