Billy's car is like mine though he has full aero setup and runs full slicks but you can see from his video how quick a sorted M3 is:
Oi!
Yea probably true.
Plus the 2500 pads, utter trash, we came down the back straight and as Gibbo can attest... for a moment it didnt seem like the car was going to stop at all
I was there on Monday doing 1:21-1:22s in my M3, loads of time left in cornering speed too. I'm determined to get sub 1:20 this year as I've had a pro driver do a 1:18 in my car before a proper diff was fitted and decent tyres.
And we all know Kindai drives like a grandma on circuits with more corners than straights anyway
Very nice driving. Well set up car! You say he's not a pro but his driving definitely shows a level of experience and maturity.
For me the most time will be found going down through craners, its possible to go pretty much flat in an M3 down there on stickier tyres hovering around 120mph, 80mph through old hairpin then flat right to the top of the hill, for me that is where time will be found, I am lifting through whole of craners and lifting off up the hill where I would normally be flat, but the whole clunk thing quite off putting and the car I feel felt a bit under damped on those high speed sweepers, think another 1/3 turn compression in front and 2/3rd in rear on compression as rear felt softer. could have course be those big sidewalls on the tyres though moving.
I'm flat from the first turn until the tiny bit of straight at craners before the left hander, quick lift and then back on the power. Flat after old hairpin up to the top. I can definitely carry much more speed through all the corners as the back end was never loose when I was there.
You coming to Oulton then? I mentioned it to Kindai. I've got a garage booked but 3 of us won't fit in 1 garage.
I'm running KW v3 and Direzzas. Turner ARB F&R too.
Come race my MX5 in a 24 hour race. Three drivers, OCUK decals, weekend out for the forum and pots
Come on, let’s do it!!
Can you share your KW V3 settings please?
Heard amazing things on the Direzzas, M3 guys who have tried cups, cup2s, NS-2R's, 595RS, slicks, trofeo r's and 888rs all said the Direzza was the best and within 1s of slick lap time so would love to try those at some point, they sound insane, would you recommend them like others do?
If you turn volume up you will hear my issue which became a major issue on drive home. Through craners and through old hairpin you will hear a solid clunk and you hear it again through the chicane coming onto the pit straight.
Car has had this for months but not as loud, no one can identify, but drivinh home this noise was happening like crazy really made me take it very easy as over uneven surface I was getting multiple clunks and if I steer left to right a real solid clunk and it can be felt in steering and through base of seat.
My guess is something crazy like the actually differential is lose, maybe top bolt come undone, but its why I took the car very easy through craner curves as lets just say its quite off putting when you know something mechanical is moving that should not and as now whatever has plagued me for months has now come very lose, hoping when I jack it up later I can spot it and properly fix it.
I love how in Gibbos posts you can actually read his excitement.
I might have to try my hand at this track malarkey.
Fuel?
Insurance?
Track oriented pads?
Noises on track should never be ignored. They can be unsettling and usually difficult to track down too, annoyingly. When I went to the Ring last time I had a clicking noise coming from the front of the car. We took it to a local garage or two and no one could work out what it was so I had to give up and park it as last place you want to take a risk is a wet Nurburgring. Got home, took it down to a specialist and turns out common issue on certain R8's where the wheel can get to a point where it clicks under stress on the hubs. Audi have a fix to a known problem....£120 tub of grease that the add FOC.
Bloody cars!!!!
Half a tank
100 quid for a gtr covered to 50k, imagine a bimmer would be half that
No idea on the pads though, thats down to preference
GTR has the same, it can be triggered as simply as lifting the car on a ramp and putting it back down again, but it causes a horrible horrible clicking noise.
Usual fix, untorque the nuts slowly, eventually you'll hear a click on one which was just slightly out (talking tenths of a mm) and then re-torquing it back up sorts it.
If not, then wheels off, wire brush on the contact points and a very thin layer of copper grease, the thinnest stuff you can find, will usually sort it.
Fuel cost doesn't warrant worrying about by the looks of it but just did a quote on Morris trackday and they want £198
