I don't bother at all, each to their own though. General cost for me works out around £500 per track day.
DS2500 are crap, no idea why they keep getting recommended. I’m running RS29 and more then happy with them.Yeah DS2500 on 1800kg isn't gonna cut it! Just get some RS29 on there and live with any road squeal. Rather have squeal on the road than binning it on track
Seems to be on the vertical axis (not rotational and doesn't occur on acceleration or breaking). Maybe engine mount or something similar thats given up?
Yes but people under estimate how capable a well sorted E46 M3 is, remember I got this to do track work instead of a sorted 911. An average driver and a sorted E46 M3 can go quick, stick a good driver in and they go very quick.
I am thinking loose steering rack or a failed ball joint. Engine and gearbox are new mounts. Think its either rear rubber on front wishbone or actual balljoint, will have to jack front up tomorrow and go swinging of bits but after tonights short drive I think its 100% in the front and happens mostly on left turns and uneven/bumpy roads. Acceleration or braking does not make it happen, happens most and always with turning left.
