IF you read to end of page 1 you'd see i rectified that error.
Wahhahaha hwhwhahhahaha i win again!
You may 'win', but your system is a fail compared to the description.
*wanders into here by accident*
Am I right in thinking that nobody does SLI, that overclocking only ever adds a few percent anyway and that with a tiny hard drive he doesn't actually need a bluray writer ?
If so, halve the cost of the case, motherboard, power supply and the fan and buy an i7, so really that's starting from scratch again.
I swear building PC's these days is nothing to do with function but all about following geek fashion - spend £115 on a PSU, that was daft 8 years ago and it's daft now.
bits you got me wrong buddy. My kick ass system is all about function. Funcation as it will be for next 5 year easy.
How? by the use of i7 cpu's that i put in this high end board and gfx that support x16 pci... once the right time is here.
As you look at the future you will see my build is way ahead of current time.
+1 get corsair or coolmaster cpu will last at least 5 years!
/facepalm
Your system if anything is behind current times by a long shot.
It wont play the latest demanding games at max res on ultra either, better get back to the drawing board with that comment.
My system is now behind the times, but it makes yours look like its from the 90s, please do some research when building your first computer.
i crank that i2500 k to 5ghz
If things get slow just throw in another 570... or upgrade to 680gtx... Thats how smart I am!
Why not just ditch the 570 and save for a 680? Or even up the current multi card budget and get a pair of 580's? Pretty sure OcUK were selling 580's for around £280 a card last week.
You are also very very optimistic on getting a 2500K to 5ghz, the fact remains that very few SB chips will hit 5ghz at reasonable enough volts on air. While on the subject of chips, as you are yet to buy anything meaningful, why don't you hold out a few weeks, grab a Z77 board and a 3750K?
I have a feeling you may be in for a shock when you decide to start gaming at anything above 1680x1050 with everything maxed out with the build you have so far.
In which case good luck to you.
Though I have to agree with some other posts, it wouldn't hurt to head over to general hardware and get some help with better spec. For example I would ditch the 570 over something like the 7850 or the 448 core 560Ti, I really don't see any appeal in owning a 570 unless its the 2.5gb version.
Remember you also need to factor in the cost of fans, cables, monitoring, storage discs (you're not playing a wide range of games on a 128gb drive), mouse, keyboard, sound cards, speakers, headset. If you want it to be kick ass on a grand budget you don't want to cut any corners or buy something purely because it fits the budget.
What I would do is split that grand 60/40. Take £600 for cpu, motherboard, ram and graphics, then the other £400 for cooling, power etc...even do the build gradually so you can keep topping your budget up, my initial build started with £400 (chip board and ram) and has been getting invested in since last may, I've now spent close to £3k on it, and 10 months later near completion.
And within that budget current system specs seem kick ass.
What monitor, or resolution monitor do you have?
Little spec up for you, left out case and PSU, changed motherboard, cooler, gpu, added mechanical storage drive:
YOUR BASKET
1 x EVGA GeForce GTX 560Ti "448 Edition" *** 1280MB GDDR5 PCI-Express Graphics Card (012-P3-2066-KR) £199.99
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £163.99
1 x Crucial RealSSD M4 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CT128M4SSD2) £119.99
1 x EVGA Intel Z68 SLI (Socket 1155) DDR3 Micro ATX Motherboard (120-SB-E682-KR) £99.95
1 x Western Digital Caviar Green 1TB SATA 6Gb/s 64MB Cache - OEM (WD10EZRX) **SINGLE PLATTER** £74.99
1 x LG CH10LS28 BD-ROM 10x BluRay ROM / DVDRW SATA-II Optical Drive - Black (Retail) £59.99
1 x Alpenföhn K2 Mount Doom CPU Cooler (Socket LGA1156/1155/1366/AM2/AM2+/AM3/AM3+/FM1) £59.99
1 x Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (BLS2CP4G3D1609DS1S00CEU) £33.59
Total : £824.47 (includes shipping : £10.00).
19 inch 1440x900 or so...
PGI are you taking the mickey. You are recommending WORSE cooler, matherb, storage and optical storage. I know its 1st april but cmon man... am not that dumb.
