I do frequent forums of ophthalmologists, and they definitely do not make it as virtually risk-free as you're making it out to be.
I never said it's risk-free though. Only that other ways to correct vision have risks as well, and apart from glasses they can be and often are riskier over a lifetime. For example, people don't go blind from laser eye surgery (zero case reported in history), people do go blind from infections or injuries caused by soft and hard contact lens use every single year.
I'm sure in those ophthalmologists forums you've seen these complications from contacts, so why are
you downplaying them? ¯\_(ツ)_/¯
You see I can play this game as well!
You haven't mentioned the risk of floaters from the surgery (which is a thing), you haven't mentioned that an operation is considered successful if the patient achieves good chart vision, but if they claim to have night vision issues or some other forms of aberration it doesn't matter - still noted as successful as their vision technically has improved, which completely throws off your statistics. These issues can't always be negated by a decent surgeon either.
I'm pretty sure that list is a lot longer, a lot can go wrong with anything. I also DID mention some of these just last page!
Do you want to look at FDA's entry on contact lens risks? Or horror stories? Just Google "I went blind from contact lenses" and you'll get a ton of reports from reputable sources. I can easily say you haven't mentioned infections, corneal ulcers, epithelial damage, corneal aberrations, etc etc. That doesn't even begin with traumatic injury with contacts in the eye (which significantly compounds the damage), etc.
However despite all of this, contact lenses are safe and effective. There's no reason to fearmonger. You do the basic precautions and best safety practices and you avoid most risks, the same is true of laser eye surgery. If you go to a reputable clinic, they do their pre-operative tests completely and choose the right procedure for your eyes, the risks are incredibly low.
Most people tend to have their vision corrected on the cheap at chain brands as well, so there's a reason I did say 'good' doctors.
No arguments there, I've never recommended people to cheap out or go to chains. They're pretty bad.
So are you claiming the ophthalmologists in the world who perform laser vision correction are "bad" doctors? Any evidence to back that up?
