You have completely and utterly lost your mind
(in a good way)
You now building a pedestal for it?
I would not be surprised if i come back in 2 weeks’ time and your building a roof for the thing
LOL
cheers Craterloads, yes I'll be making a matching super strong pedestal for it also.
It was looking around at retail & seeing cheap weak pedestals for expensive asking prices that made me get my modding cap on for making one.
I dont know what it is but i don't the look of the case in the drawings but love the look of it in the actual photos
I shal certainly be keeping an eyes on this
I know mate, I've been recommended to use a render program but it's a touch on the expensive side for my liking but would make my models look as good as the real thing if not better, might save so much each month to put towards buying it, I know it would be worth it as it's a common thing for people not seeing a nice rig in it's plain sketchup form, cheers Greavesy.
Should hopefully be able to go at this regular again after such a good session, started 21:30PM last night & called it a day today at about 16:00 (took plenty of quick breaks) so feel I've got a good bit of my drive back to really get this back on now, lesson learnt, don't slack off during a project even if good things like marble power buttons do come to mind & with that in mind it's worth thinking of taking a month off a project midway though if it's a big project.
Curve panels for the gamer rig now ready & waiting to be bent & curved, yes I checked all the oval holes to make sure they work right & they do, if anything they might need bevelling slightly when it's curved to give a near seamless look or as close as I can get to that, I'll make an exaggerated tighter version of the curve for a curving jig to form it perfect which I'll do when I get some mdf.
PSU box section panels with 92mm grill & straight air though, also did a little filing to do the rough cut outside edges since it was late to keep the noise down, these parts still need an angle bar job doing on them & I'm thinking of trying the popular file it with a square file to fold it over to reduce the number of parts.
I somehow skipped taking a picture of the 140mm custom frame piece in progress but caught a couple of the 92mm fan, I stuck the templates directly to the aluminium because of lifting problems & they totally remained held down this way, hassle to clean off but worth it to be able to see what I'm cutting properly.
By this time it was ok to use the noisy disc sander to finish off all the external edges to the lines.
So now getting higher & moving into the gamer mobo area & started using an aluminium flat bar for a drill guide, easier to see the alignment & don't need a deep one for normal panels, this method is far more accurate than my drill press.
Feels like the land of good progress within 24 hours.
There are still a bunch of decorative panels to make for the HTPC I'm not exactly looking forward to cutting
& the pci/io pieces which should be nice & easy with the saw & many more bits to do but next session I'll try to finish off the fan frames, got 4 more 2mm pieces for the 2 120mm fans to make & then 8 1mm ones, might do the rods for the frames also & make a few spares for in case I screw up drilling any.
I'll also try to get the power switch mechanism designed, ordered some of the needed bits, couple of Lian Li cable replacement kits, I like having writing on the plugs for what the cables are for & the switch will do fine for this, only thing I'll need to order is springs unless I can recycle some from some old battery taking device.
BTW I know, brightness a step or 2 or even 3 too high in the shots.
