LG 27GR95QE (worlds first OLED 240hz 2560x1440p) launches 28 December
6 Feb 2019
LG's 27 inch 240hz gaming monitor is here and it's $999usd
PICTURE QUALITY​
    • Screen Size
    • 26.5"
    • Display Type
    • OLED
    • Color Gamut (Typ.)
    • DCI-P3 98.5%
    • Color Depth (Number of Colors)
    • 1.07B
    • Pixel Pitch (mm)
    • 110.8 PPI
    • Response Time (GTG)
    • 0.03ms (GtG)
    • Refresh Rate
    • 240Hz
    • Aspect Ratio
    • 16:9
    • Display Resolution
    • QHD
    • Resolution
    • 2560 x 1440
    • Brightness
    • TBD
    • Contrast Ratio (DFC)
    • 1500000:1 (Typ.) TBD (Min.)
    • Viewing Angle
    • 178º (R/L), 178º (U/D)
    • Surface Treatment
    • Anti-Glare, Low-Reflection of the front polarizer
INPUT/OUTPUT​
    • HDMI
    • Yes x 2
    • DisplayPort
    • Yes x 1
    • Headphone Out
    • 4-pole (Sound+Mic)
    • USB Up-stream
    • Yes (1ea/ver3.0)
    • USB Down-stream
    • Yes (2ea/ver3.0)
    • SPDIF out
    • Yes
POWER​
    • Type (w/ Watt):
    • External Power (Adapter)
    • Input
    • 100~240V (50/60Hz)
    • DC Output
    • 19V, 5.79A
    • Power Save/Sleep Mode (Max)
    • Less than 0.5W
    • DC Off (Max)
    • Less than 0.3W
    • Power Consumption (Typ.)
    • TBD
    • Power Consumption (Max.)
    • TBD
SPECIAL FEATURES​
    • NVIDIA G-Sync™
    • G-SYNC Compatible
    • Adaptive Sync
    • AMD FreeSync™ Premium
    • Black Stabilizer®
    • Yes
    • Dynamic Action Sync®
    • Yes
    • Crosshair®
    • Yes
    • Smart Energy Saving
    • Yes
    • Reader Mode
    • Yes
    • H/W Calibration (True Color Pro)
    • Ready
    • Color Calibrated
    • Yes
    • OnScreen Control (OSC)
    • Yes
    • HDR (High Dynamic Range)
    • HDR10
    • HDR Effect
    • Yes
    • Auto Input Switch
    • Yes
    • FPS Counter
    • Yes
    • 4-Side Virtually Borderless Design
    • Yes
    • User Define Key
    • Yes
    • VESA DSC
    • Yes
    • VRR
    • Yes
    • RGB LED Lighting
    • Hexagon Lighting
    • True Color Pro
    • Yes
SOUND​
    • Speaker
    • No-built in speaker
    • DTS HP:X
    • Yes
DIMENSIONS/WEIGHTS​
    • With Stand (WxHxD)
    • 23.8" x 22.6" x 10.2"(Up) 23.8" x 18.3" x10.2"(Down)
    • Without Stand (WxHxD)
    • 23.8" x 13.8" x 1.8"
    • Shipping Dimensions (WxHxD)
    • 31.8" x 7.1" x 20.9"
    • With Stand Weight
    • 16.2 lbs
    • Without Stand Weight
    • 11.1 lbs
    • Shipping Weight
    • 24.3 lbs
STAND​
    • Tilt(Angle)
    • -5º ~ 15º degree
    • Swivel (Angle)
    • -10º ~ 10º degree
    • Height(mm)
    • 0 ~ 110mm
    • Pivot
    • Counterclockwise
    • Display Position Adjustments
    • Tilt/Height/Swivel/Pivot
    • One Click Stand Set-up
    • Yes
    • Base Detachable
    • Yes
CABINET/ACCESSORIES​
    • Power Cord
    • Yes
    • Remote Control
    • Yes
    • Display Port Cable
    • Yes
    • HDMI Cable
    • Yes
    • Calibration Report (Paper)
    • Yes
    • Others (Accessory)
    • Cable Holder
    • USB A to B Cable
    • Yes
WARRANTY/UPC​
    • Limited Warranty
    • 1 Year Parts and Labour
A lot of info has not been provided yet by LG. Like max brightness in sdr and hdr, and anti burn in features and other things.
It does have a matte screen which 50% of people will like and 50% will not. It also has a polarizer layer so it will be very interesting to see bright room performance between this and the QD-OLEDs
Err yes please :) When the 4K 32" version comes out I will have a hard decision to make. Does it spark joy? :)
On the flip side there will be permanent image burn-in over time so there's that. Gonna be some cheaper ones going second hand after the first year no doubt.
How's WRGB subpixels handled by Windows ClearType?
