Sorry, I just had to create an account to post this, but your screen is mounted way way too high. Speaker tweeters should be level with your ears, eyes are almost the same height as your ears so the screen position looks way off. Could cause you neck strain in the long run.
I'm six foot six - I had it mounted at this height exactly because I dislike looking down at screens. Getting a new desk made up that's 85cm high to sit under it so it will look 'less high' at that point. If it causes any issues I will just remount in a week or so after that's delivered. I've got 10cm or so I can bring it down by with a vesa extension kit. I am not at all fussed about what I am 'supposed' to do
Bit screwed with the ultimate stands as the next size up was the 45 inch which put the speakers way too high.
@sad it's working fine so far - if it fails to deliver when the new geforce comes out I will just get powered/active HDMI when the 2.1 ones release or **** about with hybrid fibre (Ruipro4k hybrid fiber) the longer cables seem to primarily have issues with the additional data sets like eARC not with pushing the main data load - of which the cX can't even eat the full 48 gigs anyway. I have had eARC crap up with anything over 3m in my media room btw, but there's f all info going around in terms of cable testing due to COVID - I've kept a close eye on the autists on AVS and no one has a f'ing clue what's going on with certs - the cable industry is well behind the set manufacturers. https://www.avsforum.com/forum/168-...y-reliably-support-48-gbps-hdmi-2-1-a-11.html
