Welcome to the ThreadDoes anyone know what OLED Light I should use if I want 120 nits for SDR Game Mode on my 48CX? Anyone measure?
I had to change my desktop speakers to ensure the sound matched what I had on screen..
I skipped the 48 and will be going straight to 42. It will be a very nice size for my needs. Hopefully being that it will be on their newer ego fab, we will get screens that are even more resistant to burn in and last even longer.So who's going to switch to the 42inch version in 2022?
I am hoping with higher PPI for better text and the evo panels together with the usual caution like screen savers, hidden task bar etc it will be ok.I only use my 48 for gaming and media content, I wouldn't use OLED for desktop regardless of size.
Me. I skipped the 48C1. A nice thing on the 42C2 is the higher ppi.So who's going to switch to the 42inch version in 2022?
According to news, LG will be announcing it next month and then the release will be likely in march or April, like the C1 last year in March.When is that scheduled for UK release, for you know?
The LG G1 Evo OLED is only in 55/65/77inch no 42inch and if there was a 42inch the price will much higher than C2 next year, so you think the next OLED will be more resistant to burn in only if that was true? The only different between Evo and traditional OLED light is the nits G1 572nits compare with C1 586nits but Evo panel do have improve colour, vibrancy, contrast balance, detail, motion clarity, sharpness.I skipped the 48 and will be going straight to 42. It will be a very nice size for my needs. Hopefully being that it will be on their newer ego fab, we will get screens that are even more resistant to burn in and last even longer.
All OLED have screen savers built in that I seen, and hidden task bar is only in Windows 10/11 not in WeboS OLEDI am hoping with higher PPI for better text and the evo panels together with the usual caution like screen savers, hidden task bar etc it will be ok.
We know all that mate. We are talking about the screen that comes out next year.The LG G1 Evo OLED is only in 55/65/77inch no 42inch and if there was a 42inch the price will much higher than C2 next year, so you think the next OLED will be more resistant to burn in only if that was true? The only different between Evo and traditional OLED light is the nits G1 572nits compare with C1 586nits but Evo panel do have improve colour, vibrancy, contrast balance, detail, motion clarity, sharpness.
Which graphics card are you using? If Nvidia there is a list of PC resolutions in the control panel (you should be using these, scroll down to find them). Don't use the non-PC resolutions at the top of the list.Anyone got any ideas where I’m going wrong, ever time I restart my computer my new C1 reverts back to 720p for some reason, I can’t for the life of me work out why it won’t stay at the right resolution
That cracked it mate, thank youWhich graphics card are you using? If Nvidia there is a list of PC resolutions in the control panel (you should be using these, scroll down to find them). Don't use the non-PC resolutions at the top of the list.
Go to the TV's Devices settings (in General), HDMI Deep Colour and enable '4K' mode.
Make sure the TV is set to PC mode, press the Home button on the remote, go to Home Settings (on the far left of the screen), in the top right corner there should he an option to edit the inputs. Click on the HDMI port your GPU is plugged into and select 'PC' from the drop-down list.
Also, make sure you enable 'game optimiser' in the LG TV settings (in General) and your TV's picture mode should be set to Game Optimiser too.
That's great to hear, which of those suggestions was the solution?That cracked it mate, thank you
