- 6 Jan 2013
- Rollergirl
Was just replying to poster that they can have big panel, 4k 120hz now that will run on his 1080ti.
A 1080ti won't do 4k 120hz no matter what the TV can produce.
Well I got 1080ti driving my 4k @ 120hz in games play. Insurgency sandstorm for my main shooter.
I guess you look at apples to apples comparisons where in reviews they turn EVERY setting in the game up to high then I guess you will assume low framerates. Fact of the matter is you don't need all the post processing settings as they are there to make low resolutions look better. Don't need much if any AA either. Motion Blur. Turn all that off and you can get very good frame rates at 4k. Obviously other settings aren't all on ultra, usually after playing about with them there often isn't much difference between low or high on some settings.
If you are just going into each game and turning everything up to max, then you are doing it wrong if you use a resolution higher than 1080p.
So I know this thread won't exactly be impartial, but I was previously eyeing up the 38GL950 but that seems like a very silly purchase now this has hit the market, and them being the same price. What do you guys think?
I dont think he meant it as the 1080ti doesn't have the power to hit 120fps.
I think he means that via its hdmi 2.0 port to this TV you can't actually output to 120hz as the card is physically limited to 60hz @ 4K
You can however output 120hz @ 4K with its display port, but the TV doesn't have one.
Maybe not as good picture quality, Support firmware?
Maybe? A VA panel with that little zones isn't even going to be in the same ballpark as the 48CX when it comes to picture quality.
Considered your interpretation of his post and I still think I read it right. Cheers for your interpretation though.
If the CX series had a display port interface, then yes a 1080TI coud do 4k 120Hz in older games. It doesn't, it only has HDMI 2.1 ports. The 1080ti will never receive a firmware update, as it lacks the HDMI 2.1 hardware. Thus it's impossible for a 1080ti to ever drive a LG OLED CX @ 120Hz.
The next generation of GPU's are launching in the next few months, which will have HDMI2.1, and so will be able to drive 4K 120Hz.
this tv ticks all the boxes however few things putting me off
* Nvidia lock out gsync for 1080ti not had non gsync in over 4 years? dont know if i could temporary go back
* LG firmware update for 120hz will it actaully happen
* Size really want 32-40 as i will have multiple monitors.
* wonder if i be comfortable being so close to big screen for daily work from home. specially as i have 3 monitos
What firmware for 120 Hz is being talked about? As sits, the 48CX can do 4K@120Hz with 4:2:0 chroma with a HDMI 2.0b current GPU and 4K@120Hz with 4:4:4 with next generation GPUs.
I never said a 1080ti needs a firmware update. I read somewhere that the TV needs a firmware update to get them to run via graphics card HDMI2.1 interface, slong with the panel changing trom just G-sync to Freesync.
Dunno if the firmware update at the end of the year to allow freesync to then operate via a 1080ti. I hadn't heard of this issue either, cheers.
Not sure read multiple times there's s firmware update at end of the year but not sure for what the update is in reference too
Yeah I read to do 4.4.4 still needs a firmware update along with the Freesync firmware update. AVSforums maybe?
Mine arrives on Saturday, can't wait![]()
