Brilliant.
I'm hoping for a decent black Friday sale. The 48CX appears overpriced compared to the 55CX.
I think that's a fair price for a set like the CX.I expect the 48 to remain more expensive than the 55 due to limited supply.
John Lewis are already out of stock.
£1200 is probably the lowest it will go during Black Friday and the Christmas sales.
Looks like the update included BBC sounds and Channel Hyundia
OLED works best in a dark or low light rooms, not in bright lit rooms.
I used a 'Sanus VTVS1 stand' because it's all made of metal and not glass base like some, so I could put my 4KUHD player under the TV like in the image I also used a 'Soges adjustable lap table' but the table top was not long enough so had to use a 56x40cm half inch plywood board and screw it on the metal stand so I can move it, to put my keyboard and mouse plus microphone on and I didn't want to sit too close to an OLED in HDR when playing games, it would burn my eyes out
The TV stand
Sanus VTVS1 Universal Swivel TV Stand for 32-60-Inch Screens - Black
I notice since I installed my 3080 that I can select 12 bit colour, should I have that as opposed to 10 bit?
I'm thinking of getting this stand, can you get the TV low enough so it almost touches a soundbase or soundbar?
You need a 3000 series with hdmi 2.1 support to get above 60hz.Hi guy just got my bx tv today, i was wondering how do you get 4k 120hz? i got a 1080 ti and a 18gb hdmi cable, do i need a different hdmi cable for it? it only shows 4k 60hz right now, thanks
You can actually do 120hz over HDMI 2.0b if you use 4:2:0 but 4:2:2 does indeed require 2.1Or the AMD 6000 series. Basically the requirement is for HDMI 2.1 to use 120hz, no GPUs have that except for the new gen of cards currently being rolled out![]()
Can confirm that the update works perfect with my RTX 3080 for my 55" so no more flickering
