Or the AMD 6000 series. Basically the requirement is for HDMI 2.1 to use 120hz, no GPUs have that except for the new gen of cards currently being rolled out![]()
Still yet to receive the 3.11.26 latest firmware, LG must be doing it slowly.
Still 2 new firmwares in a week, the best support going ever.
The firmware is on the LG support website :
https://www.lg.com/uk/support/software-firmware
You unzip the firmware to a USB drive. Just follow the firmware instructions and you cant go wrong.
Hi guy just got my bx tv today, i was wondering how do you get 4k 120hz? i got a 1080 ti and a 18gb hdmi cable, do i need a different hdmi cable for it? it only shows 4k 60hz right now, thanks
You need a 3000 series with hdmi 2.1 support to get above 60hz.
You can actually do 120hz over HDMI 2.0b if you use 4:2:0 but 4:2:2 does indeed require 2.1
you mean the CX not bx!, go into Nvidia control panel click on change resolutions then to the PC and apply it, you will not get the full 120hz in all games
I'm still getting flickering above 60Hz.
how do you do that?
OKno i got a 55 bx
i did the nvidia control panel thing but it only goes up to 1440 in pc resolution! on tv resolution it does 2160p but only 60 hzI just told you how! in Nvidia control panel
OK![]()
maybe your sitting to close! I have a 55" at 120hz but then again I am sitting 4 feet away![]()
cheers I did try this yesterday evening, but the software & firmware page says no files oddly.
https://www.lg.com/uk/support/product/lg-OLED48CX5LC
No, but the link above for the manual software update did the trick.
Now cooking with gas!
Most of us on here have the LG CX48/55, so you have the BX entry-level a7 processor model the CX use a A9 Gen3 now I understand why you can't change it![]()
you understand wrong because others with a cx are having the same problems and the bx and cx in performance is the same thing
So now you fix it![]()
firmware link :
http://gscs-b2c.lge.com/downloadFile?fileId=h5ubG6a9M6AEjG7BLRh2A
Firmware update instuctions:
http://gscs-b2c.lge.com/downloadFile?fileId=dhX2MNXY4FS6Fny4i7dXg
