guys wanted to ask you what you would choose.
asus ek 3090 or gigabyte auros 3090 waterforce?
Gigabyte Auros has 2x hdmi 2.1 so i think i can set one up for game settings "pc mode" on the CX48 and the other HDMI 2.1 none pc mode so the options would be unlock like trumotion to watch movies and just select which hdmi input i use, also the auros has a little bit higher clock speed then its cheaper also price wise
Asus EK 3090 the only thing is my motherboard is also a asus so for the themed setup
help me decide pleasse
Eh I have a 3080 and it's fine for 4k 120 hz gaming. 3090 is just a massive waste of money. I'd always suggest Asus though if you are set on it - they have the best build quality this generation of 3000 series. Personally, I'd try to get an Asus Strix 3080 or Tuf OC. Or try my luck at a 3080Ti, which will likely have better performance than the 3090 for way less.
