- 19 May 2005
Got mine coming on Saturday, went for the SY8Y soundbar aswell.
About stand curve design makes it work, it should come off so able to use the TV speaker but not the stand
I also have 65" Q9FN and c9 in 65", but yes if I compare internal speakers they are crap on C9 (wall or stand mounted) compare to the Samsung. Not an issue persay for me really as I use an AVR or soundbar prior.
Would recommend if you can, pick up a soundbar, do not need to blast volumes, but even a basic one will really add to the audio even compared to the Q9FN built in speakers.
I've used mine to play a few Xbox games and while it's a far cry from a paper 5.1 system (and not as good as my cheaper Samsung but I'm putting that down to thickness) it's not that bad. When I say worse than Samsung, it's just a bit more tinny (my Sammy is a 60ju6800). One of the games was far cry and gunshots seemed fine. I turned off the AI sound though as that was doing weird stuff.Hi guys,
I bought a 55 inch C9 last week from Costco to play games in the spare bedroom. I love the picture but the sound is awful and not very clear for me using the internal speakers. I've tested a fair few games and in many of them i'm finding the dialogue to be difficult to hear but then everything else seems to get too loud. Is anyone having the same issue? I never really had this problem using my Samsung Q9FN.
I didn't really want to buy a soundbar as the room is only small and the neighbours bedroom is next to it but sounds like i might have to? To be honest it's annoyed me so much i'm thinking of returning it and getting another Samsung.
You might want to remove that - could act as a heat insulator which might damage the panel.I left the plastic on the back of mine. It’s still there.... lol
Hardly, the screen on the C9 barely gets warm lol. I’ve had mine on all day and it’s cool to the touch.You might want to remove that - could act as a heat insulator which might damage the panel.
There doesn't seems to be any pair history in that areaCan still chromecast from android devices and airplay from apple devices fine. Could try deleting pairing history under connections area?
Best price for these at present just under £2K for the 65”?
I’ve seen it for £1989 at John Lewis.
Bit the bullet and ordered it, along with the £140 insurance for 5 years against screen burn.
Looking forward to next Thursday already.
EDIT: Can someone please let me know exactly how big the footprint of the stand is? I need to buy a piece of wood to sit it on or else my Sonos Beam is going to obscure some of the screen.
@Radox-0
Thanks for that, very useful.
One last question, how high up is the bottom of the screen from the surface it sits on? Is it about 3cm? That what it looks like from that link you posted.
Looks like I need a nice piece of wood 100x26x10.
