Permabanned
- 23 Apr 2014
- Hertfordshire
Getting an error on my C9 when trying to access internet enabled apps on the TV (Disney+ etc) that the 'network is unstable'. I get the option to try again which generally doesn't work, or to close the app.
TV is connected via ethernet, going into a powerline connector to my office and an Amplifi router. Connecting via Wifi instead works fine with no issues, albeit not great throughput (hence the use of powerline).
Sky box and PS3 are connected through the same powerline adaptor (3 ethernet ports on it) and working as before. Have swapped the powerline connectors and same issue. Looking at the settings on the TV its reporting its connected. Its listed as a connected device on the Amplifi router as well.
It worked for the first 2 weeks without problem. Can't think of anything that has changed.
Any thoughts?
Tried swapping the patch cable?
