LG Flatron 29UM65-P (29") UltraWide Monitor Owners Thread
Anyone had any glitches like this?
Happens every few minutes and I managed to catch it on my iPad. Only seems to happen in Windows, never in game. using a new DVI-D cable I got when I ordered the Monitor.
DP setting of 1.2 should not be an issue as MC is using DVI. I had mine on either, but used DVI and it never did that.
You might want to try a DP cable, with the setting noted, if you have one and also make sure that the refresh rate and resolution is correct. I assume that your GPU is fine and the drivers updated etc...?
FWIW My LG seemed to be quite picky in regards to DVI cables, even though the one I had bought from here was fully pinned and purported to support the resolution etc.
When I tried a DP cable it was fine but I could no longer get into the BIOS screen as that was blanked out until Windows booted.
:confused:
The option showed even when I used DVI-D.
Here's my 29UB65-P. Very impressed, the stand is a dream to use. It slides up and down with ease, feels like some sort of gas mechanism(?) and tilts/rotates very easily too. Little disappointed to see that despite the pictures on the overclockers shop the LG symbol is red, not white but it's not as noticeable as I thought. Loving the 21:9 aspect. I thought I'd struggle to get used to a smaller screen and a wide aspect coming from a 32" TV but there's no issue at all.
Nice setup you got there! :cool:
Blame LG for those misleading images not ocuk :p
I plan on sanding the glossy finish away to give a matte finish one day though, mrk's 34um95:
Nice setup avrc!
Was this a recent purchase from Ocuk? Did you get any backlight/glow issues? Really tempted to get one!
And can someone please tell me what resoultion this monitor plays in LoL?
hi, sorry I cant screen very flicker camera will not pick disappointing :( I have send it back, your one I see flicker free
Are you sending these message from your phone or something?
:p
And yes, there is no flicker on my screen.
Keep us updated on your replacement!
Don't have the game but a quick google brought this up:
http://forums.na.leagueoflegends.com/board/showthread.php?t=4700850
