Could you not leave like 1-2cm gap? Or just move it up and down for when you need to access the OSD/turn it on/off?
And yes, same system for the 29ub65
Thanks clovis.
Not sure what the problem isProbably be something to do with AMD drivers......
Your usage?
Use this to compare size of the lg 29" screen to your current ones.
http://www.displaywars.com/
Ah I see what you mean now.
True that, the only time you would need to use it would be to turn the monitor on/off.
Only the stands are different, everything else is the same.
Yup, VESA mounting on the back although I think it is 75x75.
Yup, LG's feature, although I think there is 3rd party software that does the same thing pretty much, I just use windows built in auto snap when you drag the window to the side or hold the start button on your keyboard and hit either the right or left arrow button.
I don't use my screen for work but do like to have a video playing whilst browsing or something else and personally don't think that there is enough screen real estate for more than two windows, at least anything more than 2 is too cramped for my liking....
NP
It is a handy wee feature!
I think you should be able to run 4 screens with the 290, as long as you have 4 connection ports.....
Doesn't matter which connection you use with this monitor, DVI-D, display port, HDMI, all the same for image quality, although some people seem to have flickering with certain connections, iirc mostly DVI-D. I have tried all 3 out and haven't had any problems.
And yes there is an option to enable display port 1.2 in the OSD controls, although I don't think our monitors need it, iirc it is only required for the very high res. monitors in order to get 60HZ and/or 10 bit colour support.
DisplayPort 1.2 now includes support for Multi-Stream, allowing you to drive up to four separate monitors from a single DisplayPort 1.2 connector (requires DP1.2 monitors or Multi-Stream compatible hub)
Hi there
Spoke to LG.
Hoping to get 29" and 34" super-wide flat IPS panels early next year with FreeSync which shall be exclusive to OcUK in UK.
So IPS and Freesync, boooooooooooooooooom!![]()
For AMD GPU users looking at this monitor, you might want to hold of for a bit longer
Hi there
Spoke to LG.
Bahh humbug ...
**Goes of to read up on FreeSync and if it would be beneficial for my purpose with a 21:9 monitor**
I see this monitor has been as low as £250, is that likely to happen again would you think?
I've only about £200 budget for a monitor but really like this and could stretch a bit.
