But for an i3 with onboard GPU it would be fine?
This isnt a good choice of case to build an M-ITX gaming rig into,at least not without some modding.
It has little to no airflow and will cook higher end components.
In it's stock form I think you'd get away with an i5 750/760 and a lower power gfx card such as a 5670,any more than this and you'd be looking to mod the case.
The Q11 which is the soon to be released update to this case has the same footprint,but with "slighty" better cooling potential.
Other than that it the usual SG05/6/7 and the Lian-li Q-08.
If you dont fancy any of those Langear also has an m-itx case in the works although there's no actual release date for it yet.
I knew this would be the case. What kind of mods would you recommend, i was thinking of putting some taller feet on to the case to allow a fan to be placed underneath to either push or draw air out with air holes drilled into the bottom of the case.
This is the only thought i have had so far as i am not that experienced with modding computers to this extent.
The main reason i am willing to mod the q07 is because of the small footprint it has on the desk and also its looks. The q11 seems like a very good compromise. Also allowing me to have a full sized double slot card. Do you know when these will be avaliable ?
What is your photography kit?
