If, as you say, the new version isn't compatible with the O11D, then what other choice do you have?Yeah do you think I should get the original one? I can't decide. Is it worth it or not? (I hope you reply ASAP as the stock on amazon is depleting)
Yeah after looking further at the new one it looks similar to the v1 so I'm not sure what to get lol! I might get the v2 and then if it doesn't work return it and get the v1If, as you say, the new version isn't compatible with the O11D, then what other choice do you have?
The new one does look much better. Sounds like a plan!Yeah after looking further at the new one it looks similar to the v1 so I'm not sure what to get lol! I might get the v2 and then if it doesn't work return it and get the v1
Hmmm interesting. I currently have an NZXT Kraken X73 but if that fails then I have a backup Nocturna NH-U14S.I have just tried the Phanteks one, it would fit and allow fans underneath, but my next problem was that moving the GPU mount up like that meant my GPU would hit my CPU heatsink.
Got an EVGA GTX1080Ti FTW3, which is fairly chunky and Noctua NH-U9S CPU cooler. I expect there would be no problems with the stock Ryzen heatsink or a waterblock.
Hmmm, interesting. I currently have an NZXT Kraken X73 but if that fails then I have a backup Nocturna NH-U14S.I have just tried the Phanteks one, it would fit and allow fans underneath, but my next problem was that moving the GPU mount up like that meant my GPU would hit my CPU heatsink.
Hmmm interesting. I currently have an NZXT Kraken X73 but if that fails then I have a backup Nocturna NH-U14SI have just tried the Phanteks one, it would fit and allow fans underneath, but my next problem was that moving the GPU mount up like that meant my GPU would hit my CPU heatsink.
Yeah after looking in depth at the coolermaster photos it appears the V2 is a similar size to the V1 and will work, with the obvious improvements. I have just sent coolermaster a message asking if the riser cable in their v2 mount is replaceable with other third party ones (PCIe 4.0 for next gen of GPUs) So it looks like I'll get the V2 and then see if it works. I'll report back in a bit - I'm going away so don't expect a reply for around 10 daysAnd here is the Coolermaster one fitted. There's an absolute gnat's hair between the backplate of the GPU and my RAM, but as you can see it sits lower than the Phanteks one because the GPU doesn't hit the CPU heatsink.
Personally I would be inclined to go for the Pankteks one if you have a small CPU heatsink or waterblock - the GPU sits slightly further towards the glass side panel with the Phankets mount and you get more space underneath it for fans and a radiator.
Fair point. I'll see what they say and order one. I'll let you all know in a week or so if it works!I see no reason why it won't be, although you may not actually be able to crew a third party one into the underside of the vertical mount - but you could have it just slotted onto the GPU PCI-E connector and held on without any screws. I expect CM may say third party ones aren't compatible, on the basis they may not match up with the screwholes on the underneath of the vertical mount.
Yes you can, i have a rad and 3 fans at the bottom with a verti mount. I'm using the Phanteks variant to achieve this though i suspect a few others will offer the same.Hi, interested in buying the Lian-Li PC-O11 Dynamic Midi-Tower and wanting to know if I could install 3 fans at the bottom while having GPU vertically installed if yes which one would i need ?
Thanks
If you want to trust me your details, I am happy to post you my Cooler master one for you to try in the interim.Well unfortunately they've gone out of stock everywhere so I'll have to wait a while. I'll update this post when I manage to get my hands on one!
You're welcome mate, i was in your shoes for awhile but just took the plunge and bought multiple verti mounts to test. The phanteks ended up being the one that worked best for me and returned the others.@Jay85 thanks was worried it being the mid tower and thought I read about not being able to but that could have been with the Lian Li vertical mount , also very impressive build![]()
Wait are you sure? How much would you want for it? (It appears I missed these past couple of messages.)If you want to trust me your details, I am happy to post you my Cooler master one for you to try in the interim.
I was going to send it to you so you could try it, bearing in mind you said you couldn't get hold of one as they are out of stock.Wait are you sure? How much would you want for it? (It appears I missed these past couple of messages.)
I'm happy to send it to you and if it works for you, you keep hold of it and perhaps make a charity donation to a cancer hospice or air ambulance.
What you want to donate, I will leave upto you - £40 seems a lot. Why don't you wait until you've got it, make sure it suits your setup?Thats so generous of you! I already think it's going to fit so I'll donate £40 to Cancer Research UK. Are you sure you don't want anything for it? Also how much do you want me to pay for postage?
Okay my address isWhat you want to donate, I will leave upto you - £40 seems a lot. Why don't you wait until you've got it, make sure it suits your setup?
I don't have any need of it, I'm happy with the Phanteks one and it fits my install a bit better. Just wanted to help a fellow OCUK'er out, I'm a believer in karma and all that! I'll cover the postage, don't be silly.
Trust me your details, I will post it ASAP.
Ah when you said trust I thought that was me trusting you with me address, I didn't realise it was a feature on the website. My mistake!Got it. Don't post your address in the clear like that, send it via a trust next time![]()
