@orbitalwalsh did you find you got much better intake from your fans with the demciflex filters on the O11 D?
I was watching the video about the Lian Li filters being a bit crap. I've already removed the top filter where I have the exhaust fans.
can feel the air exhausting a lot more with the demci filters on !!!!! thats for sure !
Am I right in thinking that for pressure optimised fans, the Lian-Li filters would have less of an impact than for standard case fans?
Ah, thats pretty comprensive then, the Lian-Li filters and just terribleIs there a kit available for the 011-D or did you just by each filter panel seperately?
is it?I think the Lian-Li will only work if you are planning on having nothing below the GPU as it mounts to the bottom of the case as well as the back.
card isn't touching the fans^^^ most install with bottom support , but can just use fans to support it![]()
Really big thanks to @orbitalwalsh for introducing these Demciflex filters
the weather gets hotter lately and the windows are wide opened for 24/7, hence more dust floating in and the filters are doing their amazing jobs well!
damn kids !!! and 3rd inbound . whats worse!!!! i now have to put it in this !!! @orbitalwalsh did you confirm cubby hole size?https://www.ikea.com/gb/en/p/hemnes-desk-white-10402412/
!!! @Plec this is it... retirement from PC Gaming ! if it fits in that door and it closes... will be laid to rest like an Egyptian Pharaoh - only to be discovered again in a decade !
2 young kids and another due imminently plus a full time job - you have loads of free time...@Plec think it might just remain a piece of hardware beauty hidden away haha
Yours a Ryzen 7 while I am using a 7-year-old E3 1220v2 (just spoiled my i7 3770k deliding it, memory error on slot 1&2) with 1080Ti@Plec
Bi*ch was told it would fit... The b***h being myself .. haha ..
So heres hoping. Sure the back is solid too... So might have to cut it or figure how to wirelessly power a PSU !!!
Rtx 2080 is going to melt it and I have a poor 2700 chip that eats 1.47v for 3.9ghz all cores !!!
iTX is was forward. Sliger SM580 !!!
