Looks good but how would you (or a boiler service engineer) access the flue on the boiler since it now has a stud wall in front of it?
Did you not have to get building control to check the plans for the conversion or does it not apply because the front of the garage hasn't changed?
shouldnt be too hard or take too long to do tho?? at least it was spotted just now and not a few months or years down the line when it was too lateAs it is an intergrated no planning required, if it was a detached garage then I would have had to apply for the change of use and no planning is required for adding the window.
A little concerned about the flue now for the engineer, I may need to replace the plasterboard with some 12mm plywood/MDF and either screw or add a hinge so it is easier to access. This was a very good point raised as no one else has thought about that!
cracking job you have done there and looks extremely good. looking forward to seeing the finished pics
Thanks for the info, will take a look into it.Planning permission is not equal to building regulations. Conversion of a garage into habitable space normally requires building regulations approval.
It's likely you should have submitted a notice prior to works commencing and need to get the works inspected particularly in relation to means of escape, fire proofing, insulation and ventilation.
I'd have a read of the below before progressing any further. At your current stage it's quite easy to make minor alterations if you need to:
https://www.planningportal.co.uk/info/200130/common_projects/25/garage_conversion/2
https://www.homebuilding.co.uk/convert-your-garage-to-a-living-space/
When I had a combi boiler installed a few years ago I was told that the flue had to be accessible to be able to be inspected. My boiler is in the old airing cupboard which had a void boxed in at the top which had to be knocked out as the flue goes through it into the attic then out through the roof.
Just needs a floor to ceiling door or an extra little door at top for the flue.
Had a quick look at this and to be honest everything should be ok, all walls to the dwellng are as before and not been tinkered with, fire door is going on the new doorway into the garage and the led spotlights are fire rated.
New window has been installed using the required lintel and electrics are all installed as per guidelines.
Although I am trying to do this on a bit of a budget we haven't cut corners.
Awesome stuff, although I'm the 0.1% that actually parks a car in their garage so this would be no-no for me!
