Low performance on Cyberpunk2077 using DLSS Performance and Rt ultra ,rtx 4090
Status
Not open for further replies.
Last question. Here someone 12700K ,DDR5,Rtx 4090. Dlss quality,1440P,Rt ultra
115 fps. 92% usage.
Why i have here 90fps and 80% usage,on 12900K and DDR4 3600mhz on rtx 4090? Please dont tell me that is ddr4 bottleneck. Thaaaaaanks
But if my 3dmark scores for gpu and cpu are fine so its ok? Also without dlss i have 95-100% in games. Only in Far Cry 6 60% usage on 1440P but this game is cpu limited for sure
My system, just like in my sig below:
12700 stock
4090 stock
32Gb ddr4 xmp2
Win 11 Pro
1440 165Hz monitor.
1440 Ultra everything (not Psycho) DLSS Quality 0.75 Sharpness
1440 Ultra everything (not Psycho) No DLSS.
Anything wrong...NO
Is my CPU maxed out...Wouldnt say so looking at the above :D
Is the 4090 fantastic...YES, and very efficient at what it does ;)
Do I game like this...NO...Well, depends on the game and depends whether I use DSR to run at 4K...Which is how I play Cyberpunk and also Elden Ring.
So i am gettin identical usage and fps in this crowded area ( 5:25 start ) on 12900K. But this is 7950X on vclip . Is this normal?
115 fps. 92% usage.
I've got around 140 at the same spot. It's the memory
So why switching to DLSS PERFORMANCE it not giving me more fps? It stayed on 102fps on dlss quality and performance. Only gpu usage is changing. Something wrong?
He must be rich af because he's had top end kit for years now.. God knows how it's funded unless he's some kind of rainman level savant.
Keyword 1080p.....
Doesn't matter, it's cpu bound on my run and it's cpu bound on his run. The resolution is completely irrelevant when the CPU is your bottleneck. Quite evident by the fact, like he himself said, increasing or decreasing DLSS (which is basically the resolution) doesn't change his performance.
Status
