21mpg is mixed, generally work which is 16miles A road and 8 miles country roads.
You don't say.
On the E46 I went through sets of:
F1
PS2
CS3
Vred
452
And found the best to be PS2. Worst 452. Best value Vred as I found them to give the same grip as the CS yet the CS were a quieter tyre.
[TW]Fox;21160864 said:You got ripped off.
I haven't bought them. I was just quoting him saying he paid £130 for his from etyres, they are £205 fitted now on that site
Hmm, conti SC3 for mine from there are £205 a corner fitted (245/40/18), when did you last buy them?
[TW]Fox;21157217 said:Yes, they are 255/35/18 on the rear, which equates to about £180 each for a quality UHP tyre. The 18's with wider rears are disproportionately more expensive unfortunately.
budget tyres I would be driving a front wheel drive carHello again
Has anyone had any experience of Marangoni tyres? Im doing a little bit of research on how much tyres will cost when I get around to purchasing a 330. They seem to be well priced, and from the little info I can find, a fairly decent tyre brand.
Any experience would be great!![]()
I didn't bother buying the CS3 in the end, I don't like the tread pattern ¬_¬
There you go, a brilliant tyre whatever the weather on the E46 coupe, job done
Edit*
The Vreds are better than the PS2. I had the PS2 for 1.5 years.
