I think so I can ram quite high volts into this and it does not care. If I did the same to my reference it would melt.
Iv ordered a top,half regretting the volts locked but im not sure i should be!
If the matrix breaks sticking all them volts in are they still covered by warranty?
Also be aware you are playing the silicon lottery with the Matrix too, mine maxed out at 1150 no matter what voltage I threw at it, although I reckon I had a dud as it would hit 80c+ while gaming and the fans would be going nuts, I ended up getting a refund.
You could say the same of the TOP or any CPU/GPU I want the Matrix more for the RAM as long as it runs at rated speed ill be satified although a decent overclock would be nice![]()
Do you think I would see much improvement over a stabdard 680GTX with Matrix?
Mainly play BF series and WOT.
Isn't that bit of sacrilege running the memory at stock speed?![]()
Keep hold of your 680 and wait it out for 20nm Stanners. Swapping to a 7970 will make no difference to game play and you may see a swing to a couple of fps more on the 7970 but is that worth it to you?
I understand the upgrade itch and you may not have to wait that long for 20nm since TSMC have built a new 20nm factory to cope with demand.
My thoughts anyways.
