I know your right, just getting tempted with the old itch!
I understand that all too well and sometimes it just won't go away
Are you using Asus GPU Tweak?
It's not voltage locked, not sure what the problem is though.
Yes, Tried all of them now.
GPU-Z stays on 1.256v, There is no change on my multimeter reading direct from the card it also shows 1.256v the Voltage adjustment buttons on the card also do nothing other than adjust some nice lights.
No idea what is going on other than the card is locked for voltage or something has gone wrong.
Quite a few reports saying they are that I have read ? It seems the early ones were not but later ones are ? Lots of conflicting info.... It seems the version 1.0 board has it unlocked but the later version 1.1 it is locked...
I have my multimeter connected directly to the card and the voltage never changes from 1.256v the buttons on the card do nothing as does settings in GPU tweak. The voltage drops off when idle but I cannot maunally set it down or up that makes any difference.
What's weird is it was running fine at 1375 before I changed the drivers and set it back to stock ?
Another member posted about the same thing the other day querying about his being voltage locked. Have you flashed it with another bios?
That's one thing I've never tried, adjusting the volts via the buttons. But mine's definitely not voltage locked.
Mine still reads 1.256v in Gpuz even though I dial in 1.3v on the card. So dunno... Unless Gpuz's not picking up the adjusted voltages correctly.
My multimeter is connected directly to the card and is reading the same as GPU-Z.
The card is locked at 1.256v no matter how you try and add more it will not allow.
