mATX case with side and top exhaust fans
The vented area is 19 X 11cm if that helps.
I've taken a photo from an angle so you can see what I am working with.
The holes on the underside bare for an SSD towards the rear. The ones at the front can only be for breathing space as a fan fitted there would hit the mounting area.
I was considering moving the SSD to the bottom mount and removing the mounting area completed as have no optical drive and planning to use that space for an old PCI audio interface.
What temps do things now run with the top fan?
Does it fit in a stand or does it set on bottom with no feet? Reason I'm asking is 2x 80mm fans on bottom vents with 25-35mm of space between bottom of case and what it sets on would bring more air into and through case than top fan. With the 2 bottom intake fans you wouldn't need any other case fans. And like I already said, if you put filters on bottom vents little to no dust would get in.
Good question, the case has a stand so holes on the base are on the base rather than side.
I haven't tested existing temperatures as I'm still waiting for the CPU.
Not even beyond viewing EUFI. Does it make a difference that I've only just fitted the CPU and cooler? Does it take time for thermal paste to bed in?
Why not just buy a better case, rather than cramming some half decent hardware (Asrock AB350M Pro4-F?) into something <£20 including a no doubt rubbish PSU?
The case cost more than that and I specifically chose it for its dimensions and features.
It's not the case that's the problem given it was basically running in open air with first temperature given.
Sorry my mistake... £33.12 including a rubbish PSU.
66C with the side off, at idle is terrible.
EDIT:
Just to put it into perspective, I have one of the below running a haswell I3 (so similar TDP to most AM4 chips) and it runs silently at nowhere near that temperature:
My basket at Overclockers UK:
Total: £70.49 (includes shipping: £10.50)
If I take the components out or the case, I imagine getting very similar temperatures.
I
need a case the can stand on the floor and is much smaller than a tower. I spent a long time doing research.
What I am sayingIsaying isdis that I still don't think the case is the problem.
I've removed it from the case.
It won't stay on using a Corsair 400w PSU. I've removed the RAM but should still be able to get into EUFI. Nope, it keeps turning off even when I press delete. PSU working fine on another Motherboard.
I've got it sat on the padding it came on in the box and anti-static.
Okay, so same behaviour with two PSUs. I'm not sure what to think. The only difference now seems to be that I haven't got any RAM installed. I've just returned the RAM I was using due to incompatibility.
I should still be able to get into EUFI regardless, surely?
EDIT:
Okay, so I have it running stable and to those of you saying the temperature inside the case was terrible...
This has been running outside the case for a week. The case is not the problem and it's running pretty much idle in Windows right now after reseating the CPU and cooler. I haven't overclocked the CPU.
Despite the current temperatures showing here, it has been idling at 63-70.
Code:
CPUID HWMonitor Report
Binaries
HWMonitor version    1.4.1.0
Monitoring
Mainboard Model        B450M Pro4-F (0x00000320 - 0xEF8062C0)
LPCIO
LPCIO Vendor            Nuvoton
LPCIO Model            NCT6779
LPCIO Vendor ID            0x5CA3
LPCIO Chip ID            0xC5
LPCIO Revision ID        0x62
Config Mode I/O address        0x2E
Config Mode LDN            0xB
Config Mode registers
        00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
    00    FF FF 00 FF FF FF FF 0B FF FF FF FF FF FF FF FF
    10    FF FF FF FF FF FF FF FF FF FF 30 26 10 00 FF FF
    20    C5 62 FF 00 FF 00 00 00 00 FF 40 00 01 FF 00 01
    30    09 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    40    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    50    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    60    02 90 02 A0 FF FF FF FF FF FF FF FF FF FF FF FF
    70    00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Register space            LPC, base address = 0x0290
Hardware Monitors
Hardware monitor        Nuvoton NCT6779
    Voltage 0        1.36 Volts [0x55] (CPU VCORE)
    Voltage 1        0.34 Volts [0x2A] (VIN1)
    Voltage 2        3.38 Volts [0xD3] (AVCC)
    Voltage 3        3.38 Volts [0xD3] (3VCC)
    Voltage 4        1.90 Volts [0xED] (VIN4)
    Voltage 5        1.10 Volts [0x89] (VIN5)
    Voltage 6        0.31 Volts [0x27] (VIN6)
    Voltage 7        0.22 Volts [0x1C] (VIN7)
    Voltage 8        0.68 Volts [0x55] (VIN8)
    Voltage 9        1.05 Volts [0x83] (VIN9)
    Voltage 10        1.90 Volts [0xED] (VIN10)
    Voltage 11        0.34 Volts [0x2A] (VIN11)
    Voltage 12        0.31 Volts [0x27] (VIN12)
    Voltage 13        1.70 Volts [0xD4] (VIN13)
    Voltage 14        1.06 Volts [0x85] (VIN14)
    Voltage 15        1.69 Volts [0xD3] (VIN15)
    Temperature 0        32 degC (89 degF) [0x20] (SYSTIN)
    Temperature 1        42 degC (106 degF) [0x53] (CPUTIN)
    Temperature 3        40 degC (104 degF) [0x28] (TMPIN3)
    Temperature 5        41 degC (105 degF) [0x29] (TMPIN5)
    Temperature 6        32 degC (89 degF) [0x20] (TMPIN6)
    Temperature 7        65 degC (149 degF) [0x41] (TMPIN7)
    Temperature 8        22 degC (71 degF) [0x16] (TMPIN8)
    Fan 1            2177 RPM [0x881] (CPUFANIN)
Hardware registers
bank 0
    00    03 7F 03 D2 00 FF FF FF FF FF FF FF FF FF FF FF
    10    03 FF 03 FF 03 FF FF FF 40 00 1C 85 D4 83 E2 00
    20    59 2A D3 D3 ED 89 27 20 FF FF FF DA 00 00 00 00
    30    00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
    40    03 3E 57 FF DF 00 1F FF 2D FF FF 10 08 55 00 A3
    50    01 FF FF FF FF FF FF FF C1 FF FF FF FF 00 00 FF
    60    AA FF FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
    70    00 0A 00 20 00 41 80 58 80 58 80 58 80 FF FF FF
    80    FF 7F 1F BF FF 05 05 05 00 00 00 00 00 00 00 00
    90    0A 00 00 00 00 FD FD FD 0A 95 EF 80 FF 40 46 C4
    A0    0E FF 00 00 FF 00 00 FF 00 00 80 66 06 06 00 00
    B0    00 00 00 00 00 00 2E 00 04 00 00 34 28 00 04 FF
    C0    FF FF FF FF FF FF FF FF FF 18 06 05 FF FF FF FF
    D0    05 05 05 05 00 00 00 00 00 00 00 00 FD FD FD FD
    E0    55 80 00 00 00 FF FF FF FF FF FF FF FF FF FF FF
    F0    00 00 00 00 00 00 00 00 00 00 00 00 6C FF FF FF
bank 1
    50    29 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
    80    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    90    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    A0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    B0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    C0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    D0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    F0    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
bank 2
bank 3
bank 4
    50    01 73 FF FF 00 00 00 FF FF 1E 03 31 09 FF FF FF
    80    58 2A D4 D3 ED 89 27 D9 00 00 1C 85 D4 83 E2 00
    90    20 29 58 60 16 E8 00 2E 00 20 41 58 58 58 1E FF
    A0    20 20 20 20 20 00 7F D2 00 00 00 00 00 00 00 00
    B0    FF 1F 13 0D FF 1F FF 1F FF 1F FF FF FF FF FF FF
    C0    00 00 08 7D 00 00 00 00 00 00 FF FF FF FF FF FF
    D0    00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
    F0    00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF
bank 5
    50    D9 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 00
Hardware monitor        D3D
Hardware monitor        NVIDIA NVAPI
    Voltage 0        0.68 Volts [0x2A3] (GPU)
    Temperature 0        30 degC (86 degF) [0x1E] (GPU)
    Fan PWM 0        35 pc [0x23] (FANPWMIN0)
    Clock Speed 0        139.00 MHz [0x8B] (Graphics)
    Clock Speed 1        405.00 MHz [0x195] (Memory)
    Clock Speed 2        n.a. (Processor)
Processors
Number of sockets        1
Number of threads        8
APICs
Socket 0
    -- Node 0
        -- CCX 0
            -- Core 0 (ID 0)
                -- Thread 0    0
                -- Thread 1    1
            -- Core 1 (ID 1)
                -- Thread 2    2
                -- Thread 3    3
            -- Core 2 (ID 2)
                -- Thread 4    4
                -- Thread 5    5
            -- Core 3 (ID 3)
                -- Thread 6    6
                -- Thread 7    7
Timers
    ACPI timer        3.580 MHz
    Perf timer        10.000 MHz
    Sys timer        1.000 KHz
Processors Information
Socket 1            ID = 0
    Number of cores        4 (max 4)
    Number of threads    8 (max 8)
    Manufacturer        AuthenticAMD
    Name            AMD Ryzen 3
    Codename        Matisse
    Specification        AMD Ryzen 3 3300X 4-Core Processor
    Package         Socket AM4 (1331)
    CPUID            F.1.0
    Extended CPUID        17.71
    Core Stepping        MTS-B0
    Technology        7 nm
    TDP Limit        65.0 Watts
    Tjmax            95.0 °C
    Core Speed        4292.9 MHz
    Multiplier x Bus Speed    43.5 x 98.7 MHz
    Base frequency (cores)    98.7 MHz
    Base frequency (ext.)    98.7 MHz
    Instructions sets    MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AES, AVX, AVX2, FMA3, SHA
    Microcode Revision    0x8701013
    L1 Data cache        4 x 32 KBytes, 8-way set associative, 64-byte line size
    L1 Instruction cache    4 x 32 KBytes, 8-way set associative, 64-byte line size
    L2 cache        4 x 512 KBytes, 8-way set associative, 64-byte line size
    L3 cache        16 MBytes, 16-way set associative, 64-byte line size
    Max CPUID level        0000000Dh
    Max CPUID ext. level    8000001Eh
    Cache descriptor    Level 1, D, 32 KB, 2 thread(s)
    Cache descriptor    Level 1, I, 32 KB, 2 thread(s)
    Cache descriptor    Level 2, U, 512 KB, 2 thread(s)
    Cache descriptor    Level 3, U, 16 MB, 8 thread(s)
    FID/VID Control        yes
    # of P-States        3
    P-State            FID 0x898 - VID 0x48 (38.00x - 1.100 V)
    P-State            FID 0xA8C - VID 0x58 (28.00x - 1.000 V)
    P-State            FID 0xC84 - VID 0x68 (22.00x - 0.900 V)
    PStateReg        0x80000000-0x49920898
    PStateReg        0x80000000-0x47160A8C
    PStateReg        0x80000000-0x459A0C84
    PStateReg        0x00000000-0x00000000
    Package Type        0x2
    Model            00
    String 1        0x0
    String 2        0x0
    Page            0x0
    Power Unit        0.0
    SMU Version        46.54.00
    TDP/TJMAX        0x41005F
    TCTL Offset        0x0
    Temperature 0        66 degC (150 degF) (Package (Node 0))
    Voltage 0        1.09 Volts (CPU VDD (Node 0))
    Voltage 1        1.42 Volts (VID #0)
    Voltage 2        1.42 Volts (VID #1)
    Voltage 3        1.38 Volts (VID #2)
    Voltage 4        1.42 Volts (VID #3)
    Power 00        42.74 W (Package)
    Power 01        2.17 W (Core #0)
    Power 02        10.27 W (Core #1)
    Power 03        3.40 W (Core #2)
    Power 04        2.23 W (Core #3)
    Power 05        18.57 W (Cores)
    Clock Speed 0        4292.93 MHz (Core #0)
    Clock Speed 1        4292.93 MHz (Core #1)
    Clock Speed 2        4292.93 MHz (Core #2)
    Clock Speed 3        4292.93 MHz (Core #3)
    Core 0 max ratio    (effective) 43.5
    Core 1 max ratio    (effective) 43.5
    Core 2 max ratio    (effective) 43.5
    Core 3 max ratio    (effective) 43.5
Thread dumps
CPU Thread 0
    APIC ID            0
    Topology        Processor ID 0, Core ID 0, Thread ID 0
    CPUID
    0x00000000        0x0000000D    0x68747541    0x444D4163    0x69746E65
    0x00000001        0x00870F10    0x00080800    0xFED83203    0x178BFBFF
    0x00000002        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000003        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000004        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000005        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000006        0x00000000    0x00000000    0x00000001    0x00000000
    0x00000007        0x00000000    0x219C91A9    0x00400004    0x00000000
    0x00000008        0x00000000    0x00000000    0x00000000    0x00000000
    0x00000009        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000000A        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000000C        0x00000000    0x00000000    0x00000000    0x00000000
    0x0000000D        0x00000007    0x00000340    0x00000340    0x00000000
    0x0000000D        0x0000000F    0x00000340    0x00000000    0x00000000
    0x0000000D        0x00000100    0x00000240    0x00000000    0x00000000
    0x80000000        0x8000001E    0x68747541    0x444D4163    0x69746E65
    0x80000001        0x00870F10    0x20000000    0x004023F3    0x2FD3FBFF
    0x80000002        0x20444D41    0x657A7952    0x2033206E    0x30303333
    0x80000003        0x2D342058    0x65726F43    0x6F725020    0x73736563
    0x80000004        0x2020726F    0x20202020    0x20202020    0x00202020
    0x80000005        0xFF40FF40    0xFF40FF40    0x20080140    0x20080140
    0x80000006        0x48006400    0x68006400    0x02006140    0x00809140
    0x80000007        0x00000000    0x0000001B    0x00000000    0x00000789
    0x80000008        0x00003030    0x02009005    0x00007007    0x00000000
    0x80000009        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000A        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000B        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000C        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000D        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000E        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000000F        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000010        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000011        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000012        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000013        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000014        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000015        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000016        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000017        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000018        0x00000000    0x00000000    0x00000000    0x00000000
    0x80000019        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000001A        0x00000002    0x00000000    0x00000000    0x00000000
    0x8000001B        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000001C        0x00000000    0x00000000    0x00000000    0x00000000
    0x8000001D        0x00004121    0x01C0003F    0x0000003F    0x00000000
    0x8000001D        0x00004122    0x01C0003F    0x0000003F    0x00000000
    0x8000001D        0x00004143    0x01C0003F    0x000003FF    0x00000002
    0x8000001D        0x0001C163    0x03C0003F    0x00003FFF    0x00000001
    0x8000001E        0x00000000    0x00000100    0x00000000    0x00000000
    MSR 0x0000001B        0x00000000    0xFEE00900
    MSR 0xC0010114        0x00000000    0x0000000A
    MSR 0xC0010058        0x00000000    0xF8000019
    MSR 0xC0010063        0x00000000    0x00000000
    MSR 0xC0010293        0x00000000    0x000708AC
    MSR 0xC0010064        0x80000000    0x49920898
    MSR 0xC0010065        0x80000000    0x47160A8C
    MSR 0xC0010066        0x80000000    0x459A0C84
    MSR 0xC0010067        0x00000000    0x00000000
    MSR 0xC0010068        0x00000000    0x00000000
    MSR 0xC0010069        0x00000000    0x00000000
    MSR 0xC001006A        0x00000000    0x00000000
    MSR 0xC001006B        0x00000000    0x00000000
    MSR 0xC0010299        0x00000000    0x000A1003
    MSR 0xC001029B        0x00000000    0x1FD5C382
    MSR 0xC001029A        0x00000000    0xDA09D11F
    MSR 0xC0010293        0x00000000    0x000688AC
CPU Thread 1
    APIC ID            1
    Topology        Processor ID 0, Core ID 0, Thread ID 1
    CPUID
    0x00000001        0x00870F10    0x01080800    0xFED83203    0x178BFBFF
    0x8000001E        0x00000001    0x00000100    0x00000000    0x00000000
    MSR 0x0000001B        0x00000000    0xFEE00800
    MSR 0xC0010293        0x00000000    0x000708AB
    MSR 0xC001029B        0x00000000    0x1FD84E87
    MSR 0xC001029A        0x00000000    0xDA0A2432
CPU Thread 2
    APIC ID            2
    Topology        Processor ID 0, Core ID 1, Thread ID 0
    CPUID
    0x00000001        0x00870F10    0x02080800    0xFED83203    0x178BFBFF
    0x8000001E        0x00000002    0x00000101    0x00000000    0x00000000
    MSR 0xC001029B        0x00000000    0x1FDAA11F
    MSR 0xC001029A        0x00000000    0x393A1381
CPU Thread 3
    APIC ID            3
    Topology        Processor ID 0, Core ID 1, Thread ID 1
    CPUID
    0x00000001        0x00870F10    0x03080800    0xFED83203    0x178BFBFF
    0x8000001E        0x00000003    0x00000101    0x00000000    0x00000000
    MSR 0xC0010293        0x00000000    0x000748AA
    MSR 0xC001029B        0x00000000    0x1FDCD36B
    MSR 0xC001029A        0x00000000    0x393A8D93
CPU Thread 4
    APIC ID            4
    Topology        Processor ID 0, Core ID 2, Thread ID 0
    CPUID
    0x00000001        0x00870F10    0x04080800    0xFED83203    0x178BFBFF
    0x8000001E        0x00000004    0x00000102    0x00000000    0x00000000
    MSR 0xC001029B        0x00000000    0x1FDF25B1
    MSR 0xC001029A        0x00000000    0xFB5D60A5
CPU Thread 5
    APIC ID            5
    Topology        Processor ID 0, Core ID 2, Thread ID 1
    CPUID
    0x00000001        0x00870F10    0x05080800    0xFED83203    0x178BFBFF
    0x8000001E        0x00000005    0x00000102    0x00000000    0x00000000
    MSR 0xC0010293        0x00000000    0x0005C8AE
    MSR 0xC001029B        0x00000000    0x1FE1545A
    MSR 0xC001029A        0x00000000    0xFB5D9D44
CPU Thread 6
    APIC ID            6
    Topology        Processor ID 0, Core ID 3, Thread ID 0
    CPUID
    0x00000001        0x00870F10    0x06080800    0xFED83203    0x178BFBFF
    0x8000001E        0x00000006    0x00000103    0x00000000    0x00000000
    MSR 0xC0010293        0x00000000    0x000648AD
    MSR 0xC001029B        0x00000000    0x1FE404D1
    MSR 0xC001029A        0x00000000    0x2CEC8311
CPU Thread 7
    APIC ID            7
    Topology        Processor ID 0, Core ID 3, Thread ID 1
    CPUID
    0x00000001        0x00870F10    0x07080800    0xFED83203    0x178BFBFF
    0x8000001E        0x00000007    0x00000103    0x00000000    0x00000000
    MSR 0xC0010293        0x00000000    0x0006C8AC
    MSR 0xC001029B        0x00000000    0x1FE6A88B
    MSR 0xC001029A        0x00000000    0x2CECE765
Storage
Drive    0
    Name            Samsung SSD 860 EVO 1TB
    Revision        RVT03B6Q
    Serial            S4X6NF0M725876X
    Capacity        931.5 GB
    Type            Fixed, SSD
    Bus Type        SATA (11)
    Features        SMART, TRIM
    Volume            e:\, 931.5 GBytes (59.7 percent available)
Drive    1
    Name            Sabrent
    Serial            RKT303.3127C01077170
    Capacity        953.9 GB
    Type            Fixed, SSD
    Bus Type        NVMe (17)
    Features
    Volume            c:\, 169.1 GBytes (30.7 percent available)
    Volume            d:\, 784.2 GBytes (47.0 percent available)
USB Devices
USB Device            USB Composite Device, class=0x00, subclass=0x00, vendor=0x248A, product=0x8367
USB Device            Intel(R) Wireless Bluetooth(R), class=0xE0, subclass=0x01, vendor=0x8087, product=0x0029
USB Device            USB Composite Device, class=0x00, subclass=0x00, vendor=0x222A, product=0x0001
USB Device            USB Attached SCSI (UAS) Mass Storage Device, class=0x00, subclass=0x00, vendor=0x0BC2, product=0xAB30
Graphic APIs
API                D3D
API                NVIDIA I/O
API                NVIDIA NVAPI
Display Adapters
Display adapter 0
    ID            0x1090308
    Name            NVIDIA GeForce GT 1030
    Board Manufacturer    Micro-Star International Co., Ltd. (MSI)
    Revision        A1
    Codename        GP108
    Core family        0x138 (GP108)
    Technology        14 nm
    Memory size        2 GB
    Memory type        GDDR5
    Memory vendor        Micron
    PCI device        bus 7 (0x7), device 0 (0x0), function 0 (0x0)
    Vendor ID        0x10DE (0x1462)
    Model ID        0x1D01 (0x8C98)
    Revision ID        0xA1
    Performance Level    0
        Core clock    1265.5 MHz
        Memory clock    3004.0 MHz
Monitor 0
    Model            DP ()
    ID            TXD08C5
    Serial            TSxx00001
    Manufacturing Date    Week 27, Year 2012
    Size            0.0 inches
    Max Resolution        2560 x 1600 @ 59 Hz
    Horizontal Freq. Range    15-99 kHz
    Vertical Freq. Range    56-62 Hz
    Max Pixel Clock        250 MHz
    Gamma Factor        2.2
ACPI
ACPI Tree
