- 12 Feb 2006
- Surrey
why are people putting them in the car? i don't get why they want to see themselves do a journey they most probably do twice every single day of their life
I just got two, whats the import duty going to be?
why are people putting them in the car? i don't get why they want to see themselves do a journey they most probably do twice every single day of their life![]()
Its more like 1 hour record would equate to roughly 4GB. The battery life would limit you to a similar amount as well, the problem with a #3 is that it auto cuts off video after 30 minutes.there are ones on ebay with sound activation but this model does not. Your looking at about 40mins with a 8gb so if you place it in before the post comes in should be good enough.
If you wanted to leave unattended for that purpose a #4 might suit better. Slightly worse video quality and more duplicated frames but the video cut off point would be 50 minutes. 4GB card plus cam and for 15ish quid you would have a decent chance at catching them.Looks like the ideal device to catch the bastid at it! I was even looking at a wireless ip cams but they are too expensive, and might get stolen itself!
Mine arrived this morning, it is charging up now after a quick test and to change the clock.
Looks great from what I can tell.
