Mini-Review: Samsung 40KU6400 as a monitor
How did you got it work at RGB 4:4:4 and Full Dynamic Range?
I can only choose RGB and full dynamic range,when i choose 4:4:4 i have only limited dynamic range which i cant change as its greyed out
Unless im missing something
I just did it in the nvidia settings, I have a 1080Ti if it makes a difference.
Do you have it like this:
Can someone help me here, whatever I try I can't get past a 30FPS cap, it's in game mode and the screen info says 4k 60p when you press the middle button on the remote, but all games are capped at 30FPS no matter what settings I use.
What graphics card are you using, and what type of cable?
I had an issue until I switched to Display Port with a DP > HDMI 2.0 adapter and a good quality HDMI cable.
Tried it with two different cards and three different cables now. 1080ti and a 1070, three different HDMI cables, all good quality.
I'm not 100% sure what settings I need to use to get it to work, googling brings up nothing except a few similar but not the same sort of issues.
I received my MU6400 yesterday and had a little play, I noticed that I get a black screen for 2 or 3 seconds when watching youtube/netflix and also when clicking on Nvidia CP settings.
any clues whats happening?
I am using a 780ti and ordered a hdmi 2.0 cable from rainforest see if it helps.
update.
I installed latest nvidia 384.94 drivers for my 780ti and now my tv is displaying "Mode not supported" ?
Do I too need a display adaptor?
cheers
*edit* I've pulled plug from mains and reset the tv back to original settings but still no luck, tv wont pick up pc anymore :/
Fixed my "Mode not supported" issue.
I am unable to run UHD Colour using my 780ti so just switched it back.
might try a display adaptor see how I get on.
Double check your refresh rate whilst in game mode on the desktop, try to manually set 60hz via display adapter properties > list all modes. If that doesn't work switch to PC mode, game mode is crappy 4:2:2 and not worth the IQ degradation imo.
How do these screens cope with 1080p input? I'm fine with 4K for my Mac but I've only got a lowly PS3 and it'd be nice to know that the upscaling (or whatever the technical term is) works like a charm.
