Basically you are fitting all STI parts into your WRX. You should seriously consider just buying an STI. You can pick up bugeye STI's for very little money, and if fitted with the PPP kit it will be a massive improvement over your WRX.
I'm being a hyporcrit a bit as I used to mod but thats why i'm going to say it, dont waste your money and just get the fast car, breathing mods are ok but changing turbos and injectors etc etc etc, its just an expensive ball ache
I just dont see those mods as sensible if you're paying someone else to do it
Are you sure STI pinks are necessary? I thought the bugeye wrx's run 440cc injectors which should be good for 340bhp with an adjustable fpr. My classic has 440cc injectors and I'm planning to fit my vf35 without changing them. I agree with the fuel pump though that will be essential and I should think the clutch will last little to no time with a vf35 fitted.Don't get me wrong, there is definitely nothing wrong with modding a WRX, you do get to a point where it's just stupid expensive to go further. Just like in a classic. But I wouldn't say don't mod one because of that.
All I'm trying to get at is that it appeared as though Lee thought he could just slap on a VF35 and get it mapped.
Having just seen a picture of the exhaust Lee has aquired, I would still say he needs the following:
Walboro fuel pump
Decat up pipe
Remap
This is before changing the turbo. By all means buy the VF35 but hold fire fitting it for a bit. You want to make sure that with all the above mods that your car is actually ok and there isn't something that needs replacing, e.g clutch etc.
When you do come to fitting the VF35, get yourself a set of STi injectors (the pinks ones like you said) and get it mapped again. The problem with changing your injectors is that it's not a cheap job to pay someone to do, and ideally (well pretty much a MUST) is that you get it mapped straight away - like the same day. As different injectors obviously run completely differently.
Don't take any of what I'm saying as a stab or laying into you btw Lee, I just want to make sure you don't end up wasting a bag of money only to find there's something else wrong - or to have your expecations too high of what you can achieve for a certain price.
P.S - I would definitely definitely say change the up pipe, as I have seen the cat melt in these when they get mapped.. you can just buy an STi up pipe as they don't have the cat in them and are made of cast iron like the manifold, saves the expense of a stainless steel jobby.
Each to their own and all that. but
Those are the worst headlights I've seen!
