Quality control of the construction of many monitors leaves a lot to be desired not just the panel - I've opened a few up in more recent years and it has been shocking in some cases - extremely low quality capacitors on premium lines, bunches of cables under tension around the corners with fairly sharp surfaces so eventually the cable will break or even cause a short circuit, bits just slapped in with a bit of silver tape so that after a few years they will come loose potentially causing problems with the functionality of the monitor, bits where they've obviously found a significant flaw in the design and had to improvise in the production units resulting in bits removed and a different bit glued in which doesn't fit the design, etc.
Not always the case but I've been shocked how not uncommon it is with monitors costing 100s or even into the 1000s.
Probably the same with TVs as well.
. I'm not about to say the X34GS is unuseable, but the overshoot behaviour across the g-sync range of AW3821DW is better.
