I think mine has coil whine when running 3dmark 13. I have not had that before so not entirely sure. Basically when test starts it makes a high frequency sharp nouse which doesn't seem to be normal fan noise. It stops when switching to another test and starts again when test starts. Btw the card runs ok for 3dmark 11, cool and quiet.
What's the best to do about it?
You should be good, mine max boosts to 1124 at stock in Heaven. Can get to +125core/+0mem or +105core/+550mem for best performance, not an indication yours will do the same but your boost at least doesn't say theres anything bad about it.
Have you tried manually controlling the fan speed to see if the whine happens at a specific speed just so you can eliminate the fan from creating the noise?
It is because in some of those 3d mark tests the framerate is like 800+fps. Most cards will whine a bit at those frames.
In real world gaming when framerates are under say 100, you shouldn't hear a thing.
didn't notice that. You may be right cause I don't remember it whines when running furmark burn in test. Will do a bit more experiment to see. Cheers.metro last light![]()
92.5% seems pretty high to me. Mine is 80.3% or something. Not really sure how does it translate to overlocking. Mine at stock goes to 1110mhz in 3dmark 11. Had a little play around during lunch time and got +150 core and +300 mem max without touching voltage and power sliders. This boosts to 1210ish when running 3dmark 11 and gets P9290 score with 2500k @ mild 4.2Ghz. I think your one should do better seeing that high ASIC. Let us know how it goes.
Just installed mine today. Gave my case insides a good cleaning while i was changing from the 570 to the 670 and took me a few hours to get it all sorted.
So ive installed it stuck the 314.22 drivers on and did gpuz test thing which showed up i think boost speed up to about 1150 ish which if its true then cool. Also i got a pretty high ASIC score i think tho not really sure if its correct cos it seems pretty high like and i duno if it really measures oc potential or not but included it in the screenie anyhow.
Not tried any games or benchies yet like might later when ive had a rest from sorting it this morning.
But anyhow how does my gpuz screenie look, ok for the 161 quid non oc version?
I did not see any stains tho i think its a brown pcb or wasnt totally black. Tho to me i really didnt see a stain unless u can show what u mean with a piccy?
About oc this card, i duno if ill do it if the boost at stock goes to 1150 which is a nice bit over the stated boost id get on the box so probably be quite happy enough as is for now. Maybe next year ill try it i dunno.
Edit - Heaven benchmark just done. My 3570k is at 4ghz so a mild oc on my cpu, no oc on the gpu tho its just stock.
Max temp was about 70 but that was right at the end of the test.
Is that a good result?
What is your ASIC Quality Jono8?
One of my cards is %64 the other %78 both clock to over 1150Mhz no problem. ASIC I have found is not a great indication of OC ability.
