@BornEvil - are those the kolink (adept) sleeved cable kit? Planning a rebuild and realised I don't have extensions for GPU with my current PSU.
If so, are you happy with them quality wise? Cheers
my brother as the same case its actually very nice
will this still work with a GPU fitted? io would think it will case conflict
Same result as you. How can people leave that thing at 100%?how are you finding the pump noise on the AIO, any thing passed 55% and mine is very loud at passed 80% i can stand to be near my pc
im going to RMA it
i dont have a pump RPM readout so i had no idea it was running so fast at low PWM percentage, this dose change my mind a little about RMA'ing itPump at 20% (1300rpm)
At full speed it is ~2800rpm. At 1200-1800rpm, it is about the same loudness, but lower rpm= lower pitch humm, which I prefer.yes ive used the same fan type on a few AIO's they really are good. my pc is on the floor and at upto 900rpm there silent for me and do one hell of a job cooling.
i have my pump at 50% and it silent, when i game iv got it set to move to 70% where the game and GPU noise covers it, i'm going to see how it is over the weekend and decide Monday if im RMA'ing it.
it is a good cooler would some good cooling capacity
You’re ok with the tension on the hoses?Up and running:
I have nothing exciting to put on the screen yet, just your average waifu on Wallpaper Engine:
The tubes are fine, there is a little tension but temps seem good.You’re ok with the tension on the hoses?
I plan same build with SFX-L and ASUS tuf 4090 oc (350mm).
I came from Cerberus X, now got a Phanteks XT Pro, but I feel like the d41 will be the sweetspot
How about if your main GPU is AMD? - Obviously W10/11 supports multiple drivers to be installed, but would the additional power draw be the same?fyi, the front HDMI port uses the iGPU and it can work simultaneously with a PCIE GPU.
The problem is that i will need to install Geforce Experience and AMD Adrenalin on the same computer. And the iGPU uses ~28 watts as well as sharing RAM.
Its not worth the hassle, i'll just run HDMI cable through the back into the GPU card.
Also I'm guessing if CPU is Intel, then could use iGPU on that? (I'll be sticking with AMD CPU for the foreseeable, but good to know!)
Had considered something along those lines, but really hate the idea of running an HDMI cable out the back and back in!
I was very disappointed with the AF III. Tried about 5 units, 360 and 420. Pump is very loud. Decide to go with the EKWB Nucleus (despite the disgusting late behaviour of the company), and at 100% is dead quiet. Performing better too. Fans are just average, but don’t need more than 30% to tame the 7800x3D. May replace with Silent wings 4 later to match the rest of the fans. Had to drop the T30s as I wanted 140mm front fans (North XL) and can’t entertain the idea of mismatched fans.Same result as you. How can people leave that thing at 100%?
I run:
Fans at 40% (500rpm)
Constant line. I have not done any stability/temperature test yet, but not crashed at all yet.
I like the fans a lot though, can't get RGB working, but don't really care tbh
I believe it would be an easy mod, as the screen detached from the case isn’t too bulky.Interesting case. Not seen one designed (or modified?) to mount the screen where the (old-school!) 5.25" bays would have been.
Not that shocked by the iGPU usage. Tried running Time Spy (for giggles) on mine and it managed 4fps. At one point it was reading seconds per frame!
