POINT TO NOTE!! - I'VE STILL TO RECEIVE ANY HARIBO!!!
I told you, I'm in your order, eating your Haribo!! nom nom nom
Stelly
Recon arrived.
The only problem I can see if from the underside.
As you can see there are some heatsinks screwed and glued there.
These will probably have to be cut down a few mm to be able to fit the recon in with the rad in the roof.
