Good info re the OC value fittings, been considering all sorts myself, really want BitsPower but at 3 times the cos tof anything else I may just go for EK Barbs
xD finally you got it I still need to get mine and the corsair braided cables.
When i order all my watercooling bits n bobs im going to order the psu then .
To be honest im going to end up mirroring your cpu block etc because we have the same mobo and as you can imagine.. lol we can only get so much in our cases.
Yeah... I was glad when the CPU block fitting without any issues with the msata connector!!
Mirror away mate. I love this little case!
Not too sure if I'll bother with the braided cables for the AX. I'll get the window done first. Just trying to decide if I've spent too much money for now, or just to sod it and do it anyway! Lol
It's nice and silent compared with my previous one!!
I was glad I was fiddling about as I noticed quite a bad kink in a hose. Obviously happens when the water warms up a bit. Temp fixed it with some hose clamps until I eventually get some 45deg fittings etc. It'll more than do the job for now!
As someone recently mentioned it may be a good idea to get a couple of panels made up to hide some of the wires at the PSU cage area.
TBH - it's never seen though.
One thing I don't like is the heap of cables near the front of the case for the fan controller etc. Bit I suppose you can't have it all ways in a tiny case!
Could you route the PCI-E cables towards the far side of the PSU, then back up to the GPU? Would keep the last of the cables away from the clean side of the build.
Also you really could do with braiding or hiding the (I assume) front panel cables, as they are spoiling the overall look, which is very good otherwise
Well I have two fans running at 900rpm on the 240 rad and the two on the 120 rad at 700rpm.
It's silent!! The only thing I can hear is the mechanical hard drives.
I have two hard drives in a icybox raid enclosure. I removed the fan from it because it was noisey - but now all I hear are the hard drives spinning. lol.
