My first project log...
Daft question but is the T fitting the same as a Y splitter? Can't see anything on OcUK that seems to fit what you are saying.
Haha :D Can you link me to what I need to buy please mate? I'm guessing I need another few barbs as well? I'll ask RJK when they fittings are back in stock and have 5UB add them to my entire watercooling order :)
about that, I bought al 600 and i don't think OcUK plan on getting any more as they sold all of them at a loss :D
Are you using 7/16 tubing?
If so, email me your address in trust and i'll sort you out with some of them (for free). not like i'm running out any time soon lol
I am yeah and I'll pay you for them mate as I'm not that tight :P
Just trust me your paypal or bt info and I'll give you £10 as that'll cover the cost of posting and your time :)
So what exactly do I need then? A Y splitter with 1/4 thread and 1/2 hose diameter for my 7/16 tubing and 1 more barb or 2?
no need, I bought the fittings for less than 1p each ;)
The splitters I have are basically 3 barbs stuck together which allow the flow of water to go in any of the three directions
no, you need a fitting to stop the fluid from escaping the tube, not one for the G1/4 as that screws in to things like water blocks.
Don't worry about postage, the loose change I have everywhere is easily enough to cover it ;)
Found one so thats on its way. So to clarify, all I need to do is have a length of hose coming from that T splitter which then has the plug in the end of it. Guessing this length of hose has to be quite small as I'll lose flow from my pump due to it or won't it actually effect anything?
correct, 5-10 cm will be fine :)
My stopper arrives today (which was quick!) so thats the first of my watercooling stuff to actually turn up :O
haha
